Home > Help Needed / General Tech Chat > Distributor Help
TomBooth
Member #: 2814
Mansfield - Notts
Alright All, as some of you might have read in prvious topics, I have brought a Metty turbo complete engine off ebay a while ago, presuming it was a complete genuine item.
Turns out its not, it's been chuffed about with, alot. So after realising this I'm just double checking parts to ensure the build should go back together as well as possible.
The distributor has confused me thou, alot. The Part code is;
-Auu1081 2003 42628h 2187
After searching on here I've read this is the metro turbo dizzy, but this is where it gets confusing. It uses a late cooper carb dizzy cap an arm. from what I have seen the metro dizzy should use a rotor arm similar to 54D etc?
So to recap, the Dizzy is right, but it uses this arm and cap
http://www.minispares.com/Product.aspx?ty=pb&pid=37135
http://www.minispares.com/Product.aspx?ty=pb&pid=36504
Apposed to the rotor arm and cap that should be fitted
Anybody shed any light on it? Or does anybody know if I am alright to use this set up? Assuming the Dizzy has the correct advance etc
Tom
Anybody shed any light on this???
Edited by TomBooth on 11th Dec, 2008.
*Clapping*
Carl S
Member #: 1761
Stalker
congratulations m1nieu, you're an idiot.
TomBooth
Member #: 2814
Mansfield - Notts
How rare... Anyway...
well assuming the base of the dizzy has all the original gubbins in it and that no is the metty turbo one, it wont matter about the cap and arm as long as they fit ok.
So perhaps this is why M1nieu sent me a PM asking me to delete his account...!
Anyway onto the dizzys, I'm not super hot on the numbers, I thought that the early Mk1 metro used a 59D with an external seperate ign module.
The Mk2 metro used a 65D (I think) which is the later type dizzy as used on all Minis from carb-Cooper onwards, so from about 1991. This has the small black ign module mounted on the side of the dizzy body. On the Metro it was used earlier to this, maybe 1988-ish? In any case those part links look fine.
TomBooth
Member #: 2814
Mansfield - Notts
Brilliant, cheers lads, if there's anymore veiws on it I'll grab some pictures...
