Home > General Chat > Digital speedos uk
i was wondering has anyone used any of these before, i have seen them avertised in a few mini worlds now and they look quite smart and have a back light http://www.digitalspeedos.co.uk/rx2n.htm. just a little thought for everyone
they look good paul, bit pricey though
shop around more for the same item if poss
Hmm look how high the revs go, you would be in the bottom half constantly.
Coupe
Member #: 2178
Leyland, Lancs
He does a 9k one - look on Ebay, he sells them on there. I've not found that particular item for sale from anyone else other than this chap. I was going to get one as they seem good quality, but its just a bit rich at the moment with everything else I need for the car.
G13B
Member #: 1376
I think it look very "chinese" in the pics, probably alot better in the flesh though!
Bringing this back up again has anyone got one of these they use? I have seen they do some specifically for the classic mini using the speedo drive for the speed pick up.
I have seen quite a few others but never really liked them has anyone got info on differnt speedos as well
Had a word with them at the last show i went to, for £450 i think, you get the speedo drive, all the sensors neccessary, 1/4 mile time, 0-60 times and loads of other random gizmos, and coloured backlight. Im definately getting one in the future for mine, looks a very good piece of kit.
Coupe
Member #: 2178
Leyland, Lancs
Quite a few people are using them now. I've had one for over 2 years now. I did have an issue with it, but Jon at Digital Speedo's replaced it for me no problem. I'd recommend them to anyone.
I had one of these to fit for a customer. Good not get the rev counter working and Jon at digital speedo's didn't help much. Said he would send a new replacement but sent another used unit which still didn't work. I tried a race technology dash 2 which I had in stock, took the signals from the same places and it worked great. I'd not recommend digital speedo's
mw3
Member #: 9590
Derby
I think these are off motorbikes and jazzed up a bit, ive seen some at shows that go up to 13K.
If you want that sort of style and can cope with the revs not getting to the top of the scale might be worth going to bike scrappers? Get one off a R1 or something.
Ive got a ETB digi dash lite, top notch stuff and about £450 came with everything.
Matt W
On 14th Mar, 2012 mw3 said:
I like the look of them with the needel and speed display its got what i like the etb ones im not so keen on and there quite small i like chunky stuff. in a perfect world i want a gauge set like the original mini ones but digital i have seen some from the states which are speedo tac ect but are $400+ each.
mw3
Member #: 9590
Derby
id love the classic centre speedo but digital.
Matt W
Midas
Member #: 7555
I've been running one on the Midas for over a year now, it does what it says on the tin though it's fuel gauge didn't get on with the Metro tank sender so I wouldn't hold out any hope for the Mini sender working.
The aftersales service from John Pullara at Digital Speedos is excellent, I'd buy from them again without hesitation.
http://www.digital-speedos.co.uk/rx2n-10k-...ition-206-p.asp
Thats the one i was looking at, and at the shows they have 90mm gauges like these that could i guess be made to fit mini dashes, although a tad on the expensive side
http://www.digital-speedos.co.uk/drift-iri...gauges-24-c.asp
Dont see the point
chuck in a standard speedo and spend £450 making your car faster or in Pauls case anything to get it to run *wink*
Edited by wolfie on 3rd Oct, 2011.
Cheeky, i like the standard clocks ect but never seen them in a fg or cf dash
also i got your message neil i will give you a call tomoz mate if thats okay?
Edited by Paul R on 3rd Oct, 2011.
miniallsort
Member #: 1131
anyone else had any experience with these gauges saw the digital ones at bingley mini show 500 for a set a bit pricey but look great anyone one know where i can get a cheaper set looking a making a custom dash so wanting something a big different
slater
Member #: 1291
Suffolk / Birmingham
Dont Koso do a mini kit for 300ish?
jonny f
Member #: 9894
Dorking
I have this one, it does the job.
The rx2n kit i bpught which is mini specific was £250, but that was back late 2011
miniallsort
Member #: 1131
I'm looking at speedo gague rev gague fuel gague oil gague water gague anyone help cheaper alternatives
miniallsort
Member #: 1131
http://youtu.be/MI4XtPL5QI0
