| Home > Help Needed / General Tech Chat > MISFIRING OVER 4000 RPM? (SUPERCHARGER) | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
13th Dec, 2008 at 12:11:28am
I must say firstly though only under full beans, if i build the revs slowly its good to 6000, didnt try any further my ears started bleeding! what do u reckon? fuelling i.e not enough pressure or as i suspect timing to retarded? Or good old fashioned det? Im running 8 -10 psi 9.01 with standard metro dizzy. plug gaps ? |
13th Dec, 2008 at 01:47:01am
what sort of missfire, regular or irregular?
Edited by Sprocket on 13th Dec, 2008. On 26th Oct, 2004 TurboDave16v said:
13th Dec, 2008 at 05:28:03am
Simple things first -try some harder (cooler running) plugs. |
13th Dec, 2008 at 10:30:06am
ive got 7s in at the mo . its an mg metro dizzy with module . i would say it feels like it is suddenly out of juice over 4000rpm, m probably way off but would a dodgy battery not help matters?
13th Dec, 2008 at 10:35:44am
Sound very like the prob I had recently.New low resistance coil and hard plugs cured my problem,but it could be so many other things.Sorry I,m not more help. |
13th Dec, 2008 at 10:41:54am
No thats fine i appreciate any commments mate thanks :) it was pinking so i back off the dizzy a couple of degrees so im thinking it might be that. the head is at 26cc at mo so might take it out to maybe30cc and advance it a couple again? |
13th Dec, 2008 at 10:45:31am
You need to retard the ignition timing under boost.
13th Dec, 2008 at 11:12:44am
missfires under load !! are caused by AFR too LEAN
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
13th Dec, 2008 at 11:37:47am
7s should be fine and if the fuelling is right 9psi at 9:1 shouldn't cause problems.
13th Dec, 2008 at 11:38:09am
So a bit more profiling needed? |
13th Dec, 2008 at 11:49:38am
A trip back to the rr me thinks. |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
13th Dec, 2008 at 02:51:12pm
Fueling seems to be a problem in the supercharged ones. Get a lambda in the exhaust. Save your pistons and get it set up as well.
13th Dec, 2008 at 03:16:29pm
new after the rr on tues just gone, it cuts out everytime i come up to lights and put the clutch down which makes me think vaacuum? |
13th Dec, 2008 at 03:17:36pm
p.s fuelling was fine and everything then off the a road first set of lights and bluurghhh it dies. |
13th Dec, 2008 at 05:33:17pm
take it back th the RR operator and tell him your Not happy let him sort it out
14th Dec, 2008 at 09:27:46am
On 13th Dec, 2008 BENROSS said:
missfires under load !! are caused by AFR too LEAN well, this isnt nesecarily the case! I have had rich misfires under load aswell... |
301 Posts Member #: 2480 Senior Member Swindon |
15th Dec, 2008 at 01:16:38pm
I was having this issue with mine. Every time you came to a junction it would cut out. I had fuel leaking out from t he weber in the end from a thread somewhere. Got it sorted and ran much better. But i always set it up on a rr and get it checked evey few months. feature=mhum |
16th Dec, 2008 at 11:49:19pm
missfires under load !! are caused by AFR too LEAN well, this isnt nesecarily the case! I have had rich misfires under load aswell... well thats true but its diffrent its called fuel bogging and black smoke is present theres a marked diffrence!!
17th Dec, 2008 at 12:00:55am
17th Dec, 2008 at 10:58:34am
Hi everyone, sorted it! Had a flash of inspiration i figured it could be not a good spark at the plugs,turns out the alternator wasnt charging!! changed it sorted!! Thanks for the help guys. |
17th Dec, 2008 at 07:04:58pm
Pleased you got it sorted. Just proves that a good spark is very important with forced industion.Earlier in this thread I said I fixed my problem with a new coil and plugs so it was the same problem really. |
