Home > For Sale > T2 Turbo
rodriguez_87
Member #: 1326
Yeovil, Somerset
For sale is my T2 turbo. it is an upgraded unit from turbo technics. it is fitted with 360degree thrust bearing and stagger gap oil seal.
i bought it new this time last year and have only removed it from its sealed packaging this morning to take photos. specs are as follows:
Renault 5 GT Turbo Phase 2
Model No. TB0235
Part No. 465367-0001
Turbine Trim - 58 Turbine A/R 0.35
Compressor Trim - 49 Compressor A/R 0.48
(copied and pasted from a thread on this site)
i bought this unit as an upgrade for my turbo technics suck thru setup, but have since bought a complete turbo engine so is no longer required. looking for £350. cheers luke.
why does the actuator have two pipe connections?
Its a standard R5 actuator, they are all like this.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
And why are they all like that?
On 30th Apr, 2010 Rod S said:
Gary's description is best
Carl
Member #: 95
liverpool-on-sea
my toyota starlet turbo turbo has 2 on, ones for the operation and the others to bleed off a little bit of pressure for different boost levels
ahh cool. never knew that or seen it before *Clapping*
GaryOS
Member #: 2810
Dublin, Ireland
Ah, cheers for that Carl
