Home > Help Needed / General Tech Chat > Rear subframe bolts
m4dn35s
Member #: 243
Portsmouth
Hi
What sizes are the rear subframe mounting bolts? Gotta try and get the shell rolling and into me neighbours garage lol! Weather is getting bad and dont help the restoration when the cover blows off over night and the mini gets full up with water :(
Cheers matt
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
turboestate
Member #: 362
durham area
i think theyre 5/16 U.N.F..
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
Yeah 5/16" UNF is correct, make sure you get them long enough to thread all the way through the captive nuts as if they only go a couple of threads into the captives they will probably pull the threads out before you can get them tight enough.
m4dn35s
Member #: 243
Portsmouth
Cool cheers gonna try n see if i can get them from a supplier that we buy from at work come in bags of 25!
Cheers matt
tip when fitting - get a can of waxoyl spray - with the tube - and spray lots into the area around the captive nuts. Smear over the bolts aswell before fitting...
D
m4dn35s
Member #: 243
Portsmouth
Cheers Dave will try that
Matt
