| Home > Help Needed / General Tech Chat > Steering column Bush | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
17th Dec, 2008 at 11:09:05pm
The first (from the left) inner column is my old fcked one, that used the bottom felt type bush. the 2nd one has the later type bush.
Shit Happen's |
10th Sep, 2012 at 09:25:43am
Do they just need a bit of brute force to get the column over the bushes? Mine isn't playing ball... On 11th Feb, 2015 robert said:
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
10th Sep, 2012 at 09:55:00am
I decided to make a new one rather than play with the std one, quite happy too as I just have 2 nylon bushes to fit easily now and a CDS tubular inner column!
Edited by topcat on 10th Sep, 2012. www.topcatcustom.co.uk |
10th Sep, 2012 at 10:23:19am
I recall having issues with this before; is there not a ring in the outer column to retain the bush? I may be completely wrong but I recall the later columns had this ring further up the column than the earlier ones. |
10th Sep, 2012 at 11:43:21am
Im struggling to get the top bush in the column. Tried fitting it to the sleave first and the column first, but no luck. they are the same type of bushes as I removed from it... On 11th Feb, 2015 robert said:
