Home > Technical Chat > Turbo Transmission Specs
Dr. jinG
Member #: 368
Roseville, CA (USA)
I have a MG Metro Turbo engine and tranny, and no one (on another board) has been able to give me specifics on the tranny. My one question is: Are these transmissions the stronger type (made with stronger gears and associated bits), than a standard 1275cc transmission? I would ask what the differential comes standard, but I believe the one I have has been traded out at some point anyway, so no worries there.
Thanks!
1967 Cooper 's' Turbo build @ www.drjing.com
all the same except a 3.2 final drive and a larger input nose bearing.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Thanks, iain. So, the same as later model A-series, or earlier? Keith Calver mentions that later models had uprated transmission bits as opposed to the ones from, say, the 80s...
Thanks, again!
nutter driver
Member #: 47
Not very sunny swanage
same as standard A+, other than the bits iain mentioned
Pete
same as the A+, i.e larger layshaft i think it is etc.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Iain is right *happy*
alex
AlexF
