Home > Help Needed / General Tech Chat > Protecting machined surfaces
Simon
Member #: 1865
Norwich, Norfolk
I've just painted up my head and just need to clean off the last little bits of over paint.
How can I protect the machined surfaces to stop them rusting? or do most people just paint them too?
Edited by Simon on 22nd Dec, 2008.
Light oil, pack it up in a plastic bag and store somewhere warm/dry.
as above, although i normally use wd40 as its just "there".
Simon
Member #: 1865
Norwich, Norfolk
sorry, i meant once its fitted to the car and in use...
you can ge a laquer, but I have used the thinnest of thin fine coat of spray wax, works a treat, but if you are not carefull, it can get messy
the rocker cover will piss enough oil out so it will never go rusty...
i concurr
thats because some people are inept at fitting the rocker cover gasket correctly *hehe!*
Edited by Sprocket on 22nd Dec, 2008.
