Home > General Chat > LSD output shaft swap (not sure what section to put this)
I have a pair of HS output shafts that suit Salisbury or old Quaiffe LSD.
Does anyone have potjoint output shafts for above diff that they would like to swap?
You can have my hardy spicers and S shafts too although the shafts have a little play in the splines
EDIT. You can also have my side plates, one is an S and the other is a bored out std A+ as it needs the lug for the detent spring
Paul
Edited by paul wiginton on 24th Dec, 2008.
