| Home > Help Needed / General Tech Chat > Burning Oil! | |||||||
63 Posts Member #: 325 Advanced Member |
16th Sep, 2004 at 07:32:38pm
Has anyone ever experienced / had a blue smoking engine just from oil leaking past the seals on the hot wheel of the turbo? |
16th Sep, 2004 at 08:42:54pm
Yes, except my last turbo was leaking into the compresser side too, and i have LOADs of blue oily smoke |
16th Sep, 2004 at 10:47:16pm
Did it smoke bad on tick over but clear when it was reved? |
17th Sep, 2004 at 09:55:04am
no, smoked very badly on tickover and left clouds behind the car when reved or driven.
17th Sep, 2004 at 12:20:07pm
There is no oil on the plugs, or in the inlet system - pipes carb etc..
![]() 111 Posts Member #: 265 Advanced Member Southampton |
17th Sep, 2004 at 12:43:32pm
18th Sep, 2004 at 11:48:54am
soton - Was it you valve guides? Or a warped head?
18th Sep, 2004 at 12:25:30pm
symptoms are most likely turbo
18th Sep, 2004 at 02:51:50pm
18th Sep, 2004 at 06:28:29pm
id just try a lcb on if you have one, sure fire way to see if its the turbo of not. You can get cheap ones for about £25 so may be worth getting one or borrowing one. cheaper than having a turbo rebuilt for no reason |
19th Sep, 2004 at 12:33:05pm
I think its prolly the exhaust gides.
42 Posts Member #: 352 Member |
19th Sep, 2004 at 04:03:18pm
On mine which is smoking as we speak, it chucks out loads of blue smoke, when it gets hot the smoke gets less, simple to tell its the turbo on mine (Midget rather than mini) as I can get to the oil supply for the turbo. As soon as it started to smoke I blanked off the turbo oil supply and smoke stopped, put oil supply back on and smoke back. Also then checked which side it was and its just the exhaust/turbine side as I removed the plenum to check it it was compressor side |
62 Posts Member #: 198 Advanced Member |
19th Sep, 2004 at 05:20:11pm
Running a turbo without an oil supply will no doubt ruin the bearings in a very short time, running dry for a few seconds will destroy the bearings, I wouldnt recomed doing that.
