Home > Wanted > depth gauge & cylinder bore gauge
philc
Member #: 1346
bromsgrove
as above in good working order
Jason G
Member #: 1459
En-suite user
Braintree, Essex
A vernier could be an option. They generally have a depth gauge.
I know mitutoyo veriners have gone down it price and are accurate
Edited by Jason G on 5th Jan, 2009.
On 19th Jan, 2010 wil_h said:
philc
Member #: 1346
bromsgrove
thanks jason, i thought about a vernier but wasn't sure how accurate. how much should i be looking at for mitutoyo. i have been looking at moore and wright
Jason G
Member #: 1459
En-suite user
Braintree, Essex
They are on par, if not better than moore & wright.
http://www.mitutoyo.co.uk/MitProd/mtopr.ns...CC!Opendocument
Edit...realistically nearer 0.1mm accuracy
Simon
Member #: 1865
Norwich, Norfolk
I bought a set of digital verniers from halfords the other week, 15 quid i think they were.
Internal, external and depth measurement.
Digital gauge makes reading it much easier
philc
Member #: 1346
bromsgrove
i wanted to measure the surface depth on my block and head once it had been machined to ensure it was level
Edited by philc on 6th Jan, 2009.
What do you mean by surface depth ???
Do you mean deck height to pistons ?
philc
Member #: 1346
bromsgrove
the top surface area between each bore
Do you mean those areas relative to the rest of the face just to make sure it's truely flat ???
If so a decent straight edge (ie, steel rule) and feeler gauges would suffice.
Or have I got it wrong again.....
philc
Member #: 1346
bromsgrove
good suggestion
And if you want greater accuracy than your thinnest feeler gauge, find an "old skool" engineer/technician who smokes roll-ups.....
The different "coloured" Rizzlas (sp?) are all defined thicknesses and all thinner than the smallest feeler gauges.
An old skool engineer will remember what thicknesses they are (I can't, I gave up smoking 25 years ago..)
Cut strips and use as feeler gauges in reverse, ie, lay the paper where you want to measure, put the straight edge on top and see if you can pull the strip out without it tearing.
If you're checking a block face, you really need a long straight edge to be able to check end to end as well as side to side.
philc
Member #: 1346
bromsgrove
thanks, i will keep a look out on ebay
