Home > General Chat > Wideband lambda
minster
Member #: 198
Does anyone use a wideband lambda sensor,
What output do you get from one, can you simply read the output voltage with a voltmeter as per a narrow band sensor.
Also the heating wires, ive briefly read that you need a control box of sorts, or can you cheat
anyone used these as im no electrical wizz.
Thanks
Phil
nutter driver
Member #: 47
Not very sunny swanage
try doing a search, im pretty sure there was a thread about this a little while ago......
hth,
Pete
Doodmeister
Member #: 149
Alberta, Canada
You could always build your own..
http://www.diy-wb.com
minster
Member #: 198
yeah ive done a search but I was still unsure hence the post,
Thats a good site, cheers Doodmeister, hadnt seen that one
TurboHarry
Member #: 115
Austria, near Vienna
Hi there, I am using a wideband lambdameter. Bought the DIY kit from WBO2.com. Have it mounted fixed in my turbo traveller - very useful tool. The electronics is a lot more complicated than that of a narrowband unit. You will find a lot of information on the webside above!
Harry
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
minster
Member #: 198
Is it easy enough to build, I did electronics a few years ago at college so have a basic understanding and am able to solder it up, Hopefully!
Phil
TurboHarry
Member #: 115
Mine worked perfect from the beginning - I bought 2 kits for me and a friend - we checked each others circiut board before soldering. Was a lot of work: Main unit, display even cables....
