| Home > Technical Chat > Caster camber gauges | |||||||
7th Jan, 2009 at 07:11:08pm
looking for a cheap way to do basic set up on the mins
7th Jan, 2009 at 07:13:56pm
make your own!
7th Jan, 2009 at 07:16:14pm
7th Jan, 2009 at 07:19:16pm
id sort a decent rim adapter out if i got it, as it will probably get a fair bit of use
7th Jan, 2009 at 08:32:42pm
The most difficult part is how to measure turning wheel to 20 degrees without using turnplates to do caster! The ADA has had some good results after all nothing to go wrong and you cannot beat gravity. Did some back to back tests after setting up mates seven and got comparable results with this ADA On 5th Sep, 2011 Vegard said:
7th Jan, 2009 at 09:28:04pm
Joe, the magnetic gauge would stick to your tracking gauges?
7th Jan, 2009 at 10:35:25pm
You can certainly do camber with a spirit level, tape measure and calculator. Castor can also be done this way although its a bit more tricky.
8th Jan, 2009 at 08:13:21am
On 7th Jan, 2009 Tom Fenton said:
You can certainly do camber with a spirit level, tape measure and calculator. Castor can also be done this way although its a bit more tricky. Yeah but on the budget the ADA is a better bet! On 5th Sep, 2011 Vegard said:
8th Jan, 2009 at 08:15:24am
On 7th Jan, 2009 joeybaby83 said:
ape, alloy wheels werent magnetic when i last checked :) and how can i sit it on the hub when the wheels on? On 11th Feb, 2015 robert said:
8th Jan, 2009 at 09:37:10am
How does the ADA compare in price to the MiniSpares version of the same thing? |
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
14th Jan, 2009 at 12:05:00pm
Some cheap turn tables going here
14th Jan, 2009 at 12:19:02pm
Jim, would he be interested in a deal?
14th Jan, 2009 at 12:21:53pm
I'm sure he would made, give him a call 07973 163451 tell him I gave you his number On 15th May, 2009 TurboDave said:
14th Jan, 2009 at 12:35:26pm
Cheers Jim "Turbo's make torque, and torque makes fun"
14th Jan, 2009 at 01:06:54pm
Might as well take them out of my watch list now then!! |
14th Jan, 2009 at 04:59:32pm
I used 2 floor tiles with a bit of grease between them for turnplates, a 6"digital spirit level and a bit of angle alloy to make it go rim/rim for camber and a bit of maths for castor. finally a digital caliper to measure with
Edited by Turbo Tel on 14th Jan, 2009. website:- http://www.terryhunt.co.uk
14th Jan, 2009 at 05:26:05pm
endaf wants to let the auction run, so feel free to watch (just dont bid lol) "Turbo's make torque, and torque makes fun"
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
14th Jan, 2009 at 06:59:01pm
I saw a video on youtube the lad used 2 floor tiles with a bit salt between them it seemed to work a treat.
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
14th Jan, 2009 at 07:45:32pm
I bought this kit at my local garage when they stopped service cars…a brown envelope with £200 and the kit was mine, a lot of garages have switched to laser so there must be tons of "old school" stuff out there
internationally known as "big" swede |
![]() 22 Posts Member #: 710 Member Amsterdam, The Netherlands |
14th Jan, 2009 at 09:35:46pm
If you have an iPhone of iPod you can use the free iHandy Level application as an accurate digital level. I tried it on my Mini last night and it worked very well. Be sure to calibrate it first on a flat surface.
Edited by thimo on 14th Jan, 2009. |
24th Aug, 2010 at 11:22:19am
Has anyone ver used the Minispares/Calver tool for this job?
24th Aug, 2010 at 09:28:00pm
24th Aug, 2010 at 10:38:15pm
On 24th Aug, 2010 Joe C said:
what puzzles you? Either I'm thick, or the instructions don't make sense. I'll get it here once I get to the garage. On 13th Jul, 2012 Ben H said:
25th Aug, 2010 at 01:01:02am
I have, what do you want to know? |
25th Aug, 2010 at 04:21:42pm
I use one, theyre not spot on accurate but good enough for what I do. Simple enough to use, though I have to read the instructions atleast twice every time I use them.
I seriously doubt it! |
