| Home > Technical Chat > Clutch issues | |||||||
18th Sep, 2004 at 10:51:23pm
What is the reason why an engine with exessive axial movement will drop the revs when the clutch is depressed? On 13th Jul, 2012 Ben H said:
19th Sep, 2004 at 10:46:35pm
Its the crank touching the block, or to be more accurate the bearing housing.
AlexF |
20th Sep, 2004 at 09:43:29am
a heavy diapraghm will pull very hard on the thrusts which will slow it down i guess. simple way ive always seen it. probably not right mind!
24th Sep, 2004 at 09:46:07am
Now that I've adjusted the 1/4" bolt in, so that there's 1cm between it and the clutch lever, the clutch is fine.
84 Posts Member #: 255 Advanced Member |
21st Oct, 2004 at 10:31:45pm
Your thrust bearing, if not of the floating type, will not be "perfectly* in line with the centre of the nose of the crank, and hence not ride perfectly on the end of the clutch diaphragm if you are on non-verto type. The heavier the diaphragm is, the more you will notice the mis-match.
29th Oct, 2004 at 05:55:52pm
Well, I'd like to blame Canada, but I guess the thrusts are the reason:
Edited by Vegard on 29th Oct, 2004. On 13th Jul, 2012 Ben H said:
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
29th Oct, 2004 at 08:42:26pm
I'll be checking my thrusts when I pull my engine this winter.
30th Oct, 2004 at 01:06:16am
That must've been more than 3 thou...
30th Oct, 2004 at 08:03:46am
Yes...
30th Oct, 2004 at 07:43:28pm
i had a car at work a couple of months ago that had 2.4mm of crankshaft endfloat(that was measured without even stripping off any engine components)
