| Home > Help Needed / General Tech Chat > ignition timing question | |||||||
![]() 213 Posts Member #: 249 Senior Member |
19th Sep, 2004 at 01:43:46pm
hi all,when i set my car up to the metro turbo factory ignition timing setting it doesnt run that well.....ive advanced it a few degrees and it is a lot better.....my question is,until i get to a rolling road for a full set up could i advance it until i get pinking and then turn it back gradually until the pinking stops....or is this a bad idea or not the ideal setting??? |
19th Sep, 2004 at 03:18:02pm
I set mine at 17deg and it advances to 25deg, all engines are different but locking the advance weights in the distributor (something i need to do) and setting it at about 20deg should be fine until you get to the rollers.
Edited by T3Tone on 19th Sep, 2004. -MINI CLUBMAN 1380 TURBO- |
19th Sep, 2004 at 10:59:07pm
Locking the dizzy! what a strange idea T3!
20th Sep, 2004 at 12:48:50am
You silly scrot!!! -MINI CLUBMAN 1380 TURBO- |
20th Sep, 2004 at 10:28:00pm
lol Best 1/4 mile 13.2 seconds @116 mph
21st Sep, 2004 at 10:32:49am
coz that will help power delivery lol!
AlexF |
22nd Sep, 2004 at 11:34:50pm
for sure. helps mine Best 1/4 mile 13.2 seconds @116 mph
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
26th Sep, 2004 at 06:41:19pm
beware fixed advance low down can cause detonation also !
27th Sep, 2004 at 10:39:14pm
do all metro turbo vacuum units retard under boost then Stuart? Best 1/4 mile 13.2 seconds @116 mph
28th Sep, 2004 at 02:27:47am
i dimagine its not so much that they retard under boost, jsut advance under vacuum. my understanding is that the vac advance at pressures greater than atmospheric, has no effect. turbo 16v k-series 11.9@118.9 :)
28th Sep, 2004 at 10:51:12pm
I'm sure i heard they retarded from some where, but you know what some peoples ideas are like, it could be wrong. Best 1/4 mile 13.2 seconds @116 mph
29th Sep, 2004 at 08:34:41am
yep its that simple when theres vacuum theres extra advance to get things going , as the boost comes in it reverts (retards) back to the standard mechanical advance - just set ignition timing up with vac disconected , then reconect |
19th Jul, 2005 at 04:42:50pm
I'm about to start my engine for the first time. When running the engine on the starter motor, how many degrees should I see with a standard turbo dizzy?
19th Jul, 2005 at 06:50:28pm
jsut swing it until the engine starts and go from tehre?! thats how i have always done it with the electric dizzy, as you cant set it up without the engine running. turbo 16v k-series 11.9@118.9 :)
23rd Aug, 2005 at 10:02:36am
I've now tried setting the ignition to 7 degrees on 1500rpm as suggested with no vac, This was not very good at all, as the engine refused to take any throttle.
23rd Aug, 2005 at 10:13:47am
mine didnt like the vac advance at all, mine is set at 24 deg fixed but went to 40 deg with vac advance and the hc went from 400ppm to 3000 ppm but will try and beg it back to about 36 deg. always looking for them bigger bunches of bannanas |
23rd Aug, 2005 at 01:09:50pm
i ran mine at 12degrees @ 1500 no vac for ages and it was fine, since the rebuild i ran it at 8 degrees and it started pinking at full chat at avon so knocked it back down to 4 now and all seems fine. On 20th Oct, 2015 Tom Fenton said:
13 Posts Member #: 1690 Member |
30th Apr, 2007 at 03:44:56pm
30th Apr, 2007 at 03:55:49pm
Why do you want to do this?
30th Apr, 2007 at 04:05:44pm
I dont really sir, just from what bud666
30th Apr, 2007 at 04:19:48pm
Not really no. What it will do is make the car less economical when at steady speed. Leave it alone.
30th Apr, 2007 at 04:31:44pm
that "12degrees @ 1500 no vac" just meant that timed it up with the vac advance disconnected....then re-connected it afterwards, not ran without it. On 20th Oct, 2015 Tom Fenton said:
