Home > Help Needed / General Tech Chat > phase 2 with standard timing gear?
Nick
Member #: 154
Midlands
right, just getting through the engine build and i need to time the cam in now. I've got an avonbar phase 2 but i got it 2nd hand so i haven't got any figures, i've managed to get a little info off their website but it still doesn't mean anything to me.
Also can it be timed in properly with standard timing gear or do i need to upgrade?
I've had a search through the site but can't find what i'm after.
Anyone help please? it's my first engine build so i'm still learning.
Cheers, Nick.
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89
Supercharging minis since '04
get a copy of 'tuning the a series engine' phone avonbar and ask what it should be timed to, it can be done with inexpensive keys
Member #: 350
...and standard timing gear , duplex gears recomended for longer sevice and power ranges
mark4765
Member #: 249
im using the same cam but ive got a kent vernier pulley setup ....i was advised to set cam timing at 108 degrees
regards mark
Nick
Member #: 154
Midlands
cheers dudes, better get reading then! i managed to find out that full lift is at 108 degrees. might see if i can pick up duplex setup tomorrow from minispares. Any recommendations on the best setup without breaking the bank?
Cheers, Nick.
T3Tone
Member #: 252
Sunny suffolk
Minispares do a decent "budget" kit, only about £20+vat, or for an extra £5 a lightened set-up of the same. Think they come with the counter sunk screws needed for the backplate?? Dont forget to tap out the bit on the timing cover or it fouls the wider(duplex) chain.
Edited by T3Tone on 20th Sep, 2004.
-MINI CLUBMAN 1380 TURBO-
Nick
Member #: 154
Midlands
yeah i was looking at them last night on their website, i think i'm gonna go for one of their vernier adjustable types about £60ish. Or is this type gonna confuse me even more than a standard setup?
Cheers, Nick.
i wouldnt bother, offset keys do the same job and cant move *smiley*
just go for lightened duplex
Edited by iain on 20th Sep, 2004.
Nick
Member #: 154
Midlands
okay then looks like a trip to minispares this afternoon, is it best to just get a selection of the offset keys? think they do from 1 to 9 degrees.
Cheers for the help dudes!
SumpNut
Member #: 28
I belive this cam is the same as the MED t3, and i was advised to set mine to 110 degrees full lift on inlet 1
my phase 2 was 106 or 108, cant quite remember.
Nick
Member #: 154
Midlands
right, what a surprise minispares didnt have the lightened setup in stock! i've got one of the vernier adjustable types, i'll have a crack at it tonight and then ask for more help later when i fuck it up :)
Cheers, Nick.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Go for 108...
AV-R Technologies
Member #: 345
Guildford Surrey
108/110 we use 108 Ian
http://www.avonbar.com
giallofly
Member #: 164
The Stig..
Newport Pagnell
Told ya!!
AV-R Technologies
Member #: 345
Guildford Surrey
ok ok clever cloggs we did try one @ 112 er er er with a T2.5 just not enough testing nuf said
