| Home > Technical Chat > Hybrid Rockers | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
10th Jan, 2009 at 07:18:47pm
i could be talking out my rear, but it might spark some interesting convo from those more technically minded.
10th Jan, 2009 at 07:47:49pm
Isnt it the position of the rocker shaft that makes the ratio?
I seriously doubt it! |
32 Posts Member #: 2517 Member Mold, North Wales |
10th Jan, 2009 at 08:50:26pm
In Aus they have been doing it for years. |
10th Jan, 2009 at 09:15:21pm
On 10th Jan, 2009 paul wiginton said:
Isnt it the position of the rocker shaft that makes the ratio? Paul not on its own,you still need a different ratio rocker, theya re repositioned over the valve,so shaft will be further towards the rear of engine, |
10th Jan, 2009 at 09:19:15pm
Isnt it the position of the rocker shaft that makes the ratio? Paul not on its own,you still need a different ratio rocker, theya re repositioned over the valve,so shaft will be further towards the rear of engine, Very true, however, how would you go about mixing and matching the ratios without having a compex and expensive post and shaft assembly? would be easier to buy a cam shaft that will do the same job a lot better
Edited by Sprocket on 10th Jan, 2009. On 26th Oct, 2004 TurboDave16v said:
11th Jan, 2009 at 12:15:41am
Isnt it the position of the rocker shaft that makes the ratio? Paul not on its own,you still need a different ratio rocker, theya re repositioned over the valve,so shaft will be further towards the rear of engine, Very true, however, how would you go about mixing and matching the ratios without having a compex and expensive post and shaft assembly? would be easier to buy a cam shaft that will do the same job a lot better ![]() Exactly I seriously doubt it! |
444 Posts Member #: 2885 Senior Member |
11th Jan, 2009 at 12:31:34am
You need the shaft to suit the rocker, otherwise each roller tip would not be over the valve tip, 1.5's would be too far, 1.3's not enough. |
11th Jan, 2009 at 01:13:08am
has anybody seen the VVT camshafts that a companies does/used to do to replace the standard items in OHV engines....now that would be interesting for a road car!
