| Home > General Chat > Starting my strip down | |||||||
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
11th Jan, 2009 at 06:38:52pm
Took a week off work to start looking at the inside of the turbo motor as it smokes a bit........well quite alot |
12th Jan, 2009 at 07:15:52pm
well got the head off and the only thing it needs is a hone and a set of rings.
12th Jan, 2009 at 07:30:08pm
On 12th Jan, 2009 druid said:
the push rods are no good so the followers must be as well. Why is this? How are the pushrods bad? Are they bent? On 13th Jul, 2012 Ben H said:
13th Jan, 2009 at 03:16:26am
Vegard has a good point
13th Jan, 2009 at 07:07:41am
Holy crap no new rings!!!!!! anywere.
13th Jan, 2009 at 07:11:29am
A coule of photos |
13th Jan, 2009 at 07:16:03am
that push rod wear is no biggie, just file that point down and reuse:) |
13th Jan, 2009 at 07:26:50am
Hell is this ok on a turbo motor?
13th Jan, 2009 at 07:34:49am
Doh i meant Tom !!!!! |
13th Jan, 2009 at 08:29:22am
a turbo motor is kind on the valve train though... low revs and relatively mild cams, thus relatively weak valve spring needs. I have filed down that point and used 998 push rods in a 1071 engine that has seen 8500-9300 rpm quite frequently... no problem. |
13th Jan, 2009 at 10:44:41am
Thanks for that, |
13th Jan, 2009 at 08:29:47pm
got the rest in bits today.
13th Jan, 2009 at 09:00:47pm
did sprock track down a supplier of turbo rings?
13th Jan, 2009 at 09:02:06pm
whats so F**ked about the old rings?
13th Jan, 2009 at 10:08:25pm
On 13th Jan, 2009 druid said:
got the rest in bits today. All good no marks on the crank. Ring a f****ed though so i will have to get a larger set of pistons? but what to get forged? cast? omega? Any help with this one Do a search for "Hypatec". they are a good value piston from Aus. Edited by Paul S on 13th Jan, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th Jan, 2009 at 11:05:05pm
i remember now, i think he got them from 'total seal' "Turbo's make torque, and torque makes fun"
14th Jan, 2009 at 07:49:11pm
Thanks for the info |
