| Home > Help Needed / General Tech Chat > paint reactions??? | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
13th Jan, 2009 at 08:00:04pm
does anyone on here have any know how on paint spraying reactions??? have primed the inside of my mini with etch primer now i want to do the top coat which will be cellulose paint will this react???
13th Jan, 2009 at 08:05:03pm
Top coat shouldnt usually go onto etch, you should have a primer inbetween.
I seriously doubt it! |
14th Jan, 2009 at 10:53:50am
ok great so just flow a coat of cellulose primer over the etch then on with the paint??? |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
14th Jan, 2009 at 11:45:34am
yes, make sure its nice and clean though!!!! insides are nasty to spray....give me a panal any day! "Cars are a lifetime of pain" |
14th Jan, 2009 at 12:11:48pm
ok great thanks for your help! also i have just bought my paint and its cellulose and people are saying i wont get as nice finish with this and that it would be better with twin pack???? |
14th Jan, 2009 at 05:35:51pm
Twin pack is great, but only if you have an airfed mask and an extraction system - its nasty stuff to breathe,much much worse than cellulose. |
14th Jan, 2009 at 06:13:28pm
Cellulose is easy to polish runs out. Haven't had much experience with 2pk. On 19th Jan, 2010 wil_h said:
14th Jan, 2009 at 07:07:34pm
hmm, 2 pack you can get a much better finish with in my experience, you can flat it to a mirror finish, i always use 2 pack..... "Cars are a lifetime of pain" |
559 Posts Member #: 2775 Post Whore Aberdeen |
14th Jan, 2009 at 07:13:04pm
Where is everyone getting their paint from? I cant find anyone localy to sell celly or 2k and nobody is willing to post it! Any suggestions? |
14th Jan, 2009 at 07:19:12pm
On 14th Jan, 2009 lockfast said:
Where is everyone getting their paint from? I cant find anyone localy to sell celly or 2k and nobody is willing to post it! Any suggestions? eBay, there are at least three suppliers selling both 2K and celly that they really shouldn't be..... Jawell is the most used, Nu-agane probably second and centralcarproducts third, at least in terms of my useage of them - but there are others too on the bay..... Schrödinger's cat - so which one am I ??? |
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
14th Jan, 2009 at 07:47:35pm
Hi if you are going to use acrylic (cell) then make sure you prime the surface and sand with 800 wet n dry and clean all very well. i have done the inside with a can but if you want to use 2pk you will need a hv lp (high volume low presure) gun gravity fed is best and small, to make it easier for the tight places.
14th Jan, 2009 at 08:03:41pm
If your etch coat is dry and by that I mean totally gone off not just touch dry you can paint straight on top of it.
Edited by Mr Joshua on 14th Jan, 2009. Own the day
14th Jan, 2009 at 09:22:28pm
that is exactly what i needed to hear thanks alot mr joshua i have read this through and sounds spot on! how many coats of etch primer do you think?
15th Jan, 2009 at 10:09:04am
Two good coats should be good enough.
Own the day
15th Jan, 2009 at 11:40:29am
ok great thanks for that ill wait for a while then in that case gives me more time to get engine sorted |
15th Jan, 2009 at 04:46:27pm
On 15th Jan, 2009 turbo22 said:
ok great thanks for that ill wait for a while then in that case gives me more time to get engine sorted Excelent decision! Own the day
