Home > General Chat > Are these worth buying?
http://www.frost.co.uk/item_Detail.asp?productID=8086
Or should i just stick to feeler gauges etc?
I have one and find it very useful. But I got it free, not sure I'd splash out £30 on it
£25 on ebay with free delivery, still not cheep though...
I wouldnt bother. Feelers all the way for me! *tongue*
I've seen how much fun you have setting them up! Especially roller rockers...
I know better now. 15thou sliding sideways on 1.5 roller rockers. not 12thou sliding forwards and backwards.
i could imagine it being quick and easy to adjust your rocker clearance but expensive for the number of times it will be used i an year
What clearance does it set your tappets to?
Depends how many clicks you give it...
1 click = 1 thou.
So you wind in until there is no clearence then click it out until you get to your desired setting. e.g 12 clicks = 12 thou.
dazibee
Member #: 1356
TRURO, CORNWALL
Then after you have got your 12 clicks and 12 thou it all gets buggered up when your hands fractionally move the adjustment screw when tightning everything up.
I have a click adjust and can't see how they can be any better than feelers .
So you still need feelers!
TBH even if i used that tool (and i was given one) i would still use a feeler to double check. make sure the tool wasnt pissing around.
Richie
Member #: 628
it must be worth it the hand on the advert is doing a mini engine..........
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
giallofly
Member #: 164
The Stig..
Newport Pagnell
I'd spend the cash elsewhere that is for sure.
A feeler guage, a spanner and a srewdriver all day long for me.
Then rule of Nine....
JF.
looks good, how much time would this save??
