| Home > Help Needed / General Tech Chat > Fueling, any Idea's? | |||||||
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
14th Jan, 2009 at 02:54:19pm
Went to the RR today for my first set up, but fueling is causing an issue! At idle the car is fine, it'll hold rev's too, but any sort of load an rev's, leans off and dies. The carb was stripped and cleaned, then the jet cleaned out etc and it's still the same.
14th Jan, 2009 at 03:03:34pm
Balance pipe?? On 28th Aug, 2011 Kean said:
14th Jan, 2009 at 03:06:52pm
is it turbo with hif44? was the little hole cut out in the gasket between the carb and plenum not all have it
Yes i moved to the darkside |
14th Jan, 2009 at 03:07:42pm
On 14th Jan, 2009 mini13 said:
Balance pipe?? i think he refers to the part throttle lean off pipe Yes i moved to the darkside |
14th Jan, 2009 at 04:11:27pm
Had a read search and read about the Tee Piece trick, and I think I might give that a try tomorow, hopefully my new gaskets will turn up tomorow so I can fit them and try again.
Edited by TomBooth on 14th Jan, 2009. |
14th Jan, 2009 at 04:33:23pm
Its strange that it won't start when you block the carb end of the leanoff pipe, or connect the pipe. If not used It should be blocked both ends, thats what you should concentrate on.
Edited by Turbo Tel on 14th Jan, 2009. website:- http://www.terryhunt.co.uk
14th Jan, 2009 at 04:44:32pm
Good advice above. The part throttle lean off pipe is your problem. This needs to be blocked off or connected.
In the 13's at last!.. Just |
15th Jan, 2009 at 03:43:54pm
Preety sure it is fixed! Checked the gasket and the hole was there, but not open enough. so I opened that up and blocked the part lean off pipe, it was better but still died back down after revs, alot better then it was thou.
15th Jan, 2009 at 04:23:40pm
Have you checked if your fuel pressure is rising with boost? On 15th May, 2009 TurboDave said:
15th Jan, 2009 at 04:29:28pm
This problem plauged me for over a year, car would idle and run ok off boost but once the pressure came up it cut out and died turned out to be the balance pipe. ther was the smallest of holes in it and this is enough to cause all sorts of issues. What annoyed me was it was a new part one of the first bits I changed but it had the same fault. Go figure:( Edited by Mr Joshua on 16th Jan, 2009. Own the day
15th Jan, 2009 at 05:16:51pm
Not yet Jimster, going to fit a FP gauge just to make sure... |
28th Jan, 2009 at 12:49:04pm
Did you get to the bottom of the problem Own the day
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
28th Jan, 2009 at 08:12:44pm
By carb balance pipe, I mean the plastc pipe that runs from the pipe just above the fuel in, and to the spacer after the carb
i recommend replacing the plastic pipe with some other rubber fuel pipe i had a problem to do with part throttle and idle and this pipe had a tiny split in it, this is aparently commond problem not saying 100% that is but for the sake of 6" of pipe it worth a try "Tuning should be a compromise between what is possible and what is necessary"
30th Jan, 2009 at 01:48:09am
tom fitted turbo daves T piece trick and its sorted now
