| Home > General Chat > Triumph 2.5 pistons | |||||||
15th Jan, 2009 at 05:03:29pm
Anyone know anything about these, is it possible to get them ?
On 17th Feb, 2009 Rob H said:
15th Jan, 2009 at 05:34:09pm
I just thought these were the 74mm pistons? |
15th Jan, 2009 at 05:35:30pm
they are 74.7 mm I think? |
15th Jan, 2009 at 06:04:41pm
Ya there 74.7 I think I rember Sprocket mentioning that he got some somwhere ? there does not seem to be much on Google about it, I found that APT sell them but Im not sure what they are in standard format or do i need oversized ? On 17th Feb, 2009 Rob H said:
15th Jan, 2009 at 06:06:09pm
what about ordering some custom pistons from wiseco or the like? about the same price as forged pistons from the usual suspects... |
15th Jan, 2009 at 06:42:57pm
15th Jan, 2009 at 07:02:20pm
You will need to hack about 9mm off the top of the block even with a stroked crank. Custom is the way to go, then you will get the exact piston for the job :) Remember, the A series piston has a very tall crown hight compared to most other engines.
15th Jan, 2009 at 08:46:44pm
Thanks colin, Id say mike could sort me with a head gasket, do you say that JE pistons made yours in another post or am I imagining that ? On 17th Feb, 2009 Rob H said:
15th Jan, 2009 at 10:43:46pm
I think you may be getting confused with the first lot of JE pistons that were available for the A series which also required about 9mm chunk taken off the top of the block. The pistons I have are original factory Triumph 2.5 pistons and far from performance items On 26th Oct, 2004 TurboDave16v said:
16th Jan, 2009 at 12:25:15am
On 15th Jan, 2009 Sprocket said:
Big is not always better ![]() thats not what my miss says On 17th Feb, 2009 Rob H said:
16th Jan, 2009 at 12:49:21am
