| Home > Help Needed / General Tech Chat > Making my nuts hard | |||||||
15th Jan, 2009 at 07:57:44pm
The other day I stripped the thread off one of a UNF nut and as nowhere sells UNF nuts on the weekend I stuck some mild steel hex in the lathe and made up some replacements. Now I was wandering if I should heat treat them to make the threads harder to prevent me from stripping them again. Isambard Kingdom Brunel said:
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
15th Jan, 2009 at 08:48:31pm
Rob.
15th Jan, 2009 at 09:58:06pm
not if its a low carbon steel it wont,[mild steel]
15th Jan, 2009 at 10:05:36pm
OK, fair point well made.
15th Jan, 2009 at 10:26:36pm
dont over tighten them,lol,
15th Jan, 2009 at 11:13:55pm
mild steel can take alot of stretching before failing. Sometimes making a bolt too hard can make it fragile.
Edited by Jason G on 15th Jan, 2009. On 19th Jan, 2010 wil_h said:
16th Jan, 2009 at 12:40:27pm
Not if he can drop them into a bucket of carbon powder or crude oil. the carbon will be adsorbed into the surface, it may grow a few thou but its fun to do Own the day
16th Jan, 2009 at 12:48:47pm
Any form of carburising on the surface is just that - surface treatment.
16th Jan, 2009 at 01:39:32pm
On 16th Jan, 2009 Rod S said:
Any form of carburising on the surface is just that - surface treatment. Yes, you can make the surface harder that way, or by using proprietry case hardening compounds, but it won't make the slightest bit of difference to mild steel (low carbon steel) where it matters in this case, ie in the core material at the root of the threads. So just treat it carefully, ie, as said, don't overtigthen them. you will get a 2-3 thou penatration over exposed surfaces. you end up with a hard surface and softer core with the added bonus of corrosion resistance. Own the day
16th Jan, 2009 at 01:52:59pm
Agreed entirely - I've used a product "casenet" many times to achieve that couple of thou surface hardness (home made thrust/spacer washers on Imp gearboxes), but for threads, where the loading is predominantly shear stess below the surface, there will be no increase in "strength"...
16th Jan, 2009 at 01:54:52pm
well i'm glad we got that sorted ,
![]() 22 Posts Member #: 710 Member Amsterdam, The Netherlands |
16th Jan, 2009 at 03:56:05pm
Do I understand correctly, did you cut the threads by yourself? If yes, keep in mind that cut threads are less strong than rolled threads (deformation makes the iron stronger). |
16th Jan, 2009 at 04:53:22pm
On 16th Jan, 2009 Rod S said: True.
Agreed entirely - I've used a product "casenet" many times to achieve that couple of thou surface hardness (home made thrust/spacer washers on Imp gearboxes), but for threads, where the loading is predominantly shear stess below the surface, there will be no increase in "strength"... You might be less likely to damage them doing them up with the harder surface - and the corrosion resistance is a bonus - but you won't turn them into a high tensile nut :) Own the day
16th Jan, 2009 at 04:53:30pm
