Home > Help Needed / General Tech Chat > fuel filter
turbosteve
Member #: 370
Reads "my mates" max power whilst wearing my Mrs's underwear
i just did a search on fuel filters and most of you put a filter before the pump which i was planning to do, but some of you put a secound one before the regulator is this necessary ? if so why ?
need to ask one other crap question (sorry) i've forgetten where the engine earth strap mounts, any one remember?
cheers guys *happy*
earth strap can go in a number of places, sometimes from subby to clutch side of the gearbox.
sometimes they go across the dogbone as such. anywhere really that will have good metal to metal contact and isnt isolated. PLus isnt in the way of anything.
For the cost of a filter, about £1 tops i always put one in between the carb and regulator, i.e. on the low pressure side.
turbosteve
Member #: 370
cheers iain, just need to ask one other thing i want to run the new fuel line along the original route, would it be ok to run the fuel return under the car next to it ?
Go for it, use some P clips to hold it all neatly in place
*smiley*
ive never understood why you would need 2 filters? surely the one would take out all the rubbish?unless the secondary one had a superior mesh??
