| Home > Wanted > Ally sheet. | |||||||
1391 Posts Member #: 1686 Post Whore Oxford |
16th Jan, 2009 at 05:20:32pm
Hey there folks,
OMG Robert that's a big one |
16th Jan, 2009 at 05:28:42pm
I've used this company for ally recently (bar stock, not sheet) but as the price is identical, it may be the same as yours !!!
16th Jan, 2009 at 06:52:56pm
Only way to get it cheaper is to order in quantity I' afraid. Single sheet is going to be expensive, some companies charge for this.
On 16th Jan, 2009 Sam said:
Hey there folks, Im after some ally sheet. Around 2000mm x 1000mm x2mm Cheapest ive found is is 82 pound delivered to my door. But as im a tight fisted bastard is there anywhere cheaper?. there arnt really any local metal suppliers near me unfortunately thanks Sam. On 19th Jan, 2010 wil_h said:
16th Jan, 2009 at 10:38:50pm
Where abouts in the world are you?
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
16th Jan, 2009 at 10:46:10pm
Hey there folks, Im after some ally sheet. Around 2000mm x 1000mm x2mm Cheapest ive found is is 82 pound delivered to my door. But as im a tight fisted bastard is there anywhere cheaper?. there arnt really any local metal suppliers near me unfortunately thanks Sam. they are taking the piss , prob charging you 40 of the queens fin est to deliver, call them back and tell them to fook right off. carl |
16th Jan, 2009 at 10:52:25pm
Set your location in 'My Control Panel' chap and gain some possible cheap deals! :) On 19th Jan, 2010 wil_h said:
16th Jan, 2009 at 11:08:49pm
in just south of oxford, not to far from dan_up and matty.
16th Jan, 2009 at 11:11:12pm
Same place rod.
16th Jan, 2009 at 11:56:25pm
17th Jan, 2009 at 08:11:39am
A mini with a 45 and a bp320 running a tad rich even though setup on a dyno for fueling. guy was a numpt.
17th Jan, 2009 at 09:07:12am
17th Jan, 2009 at 11:43:06am
On 17th Jan, 2009 Sam said:
A volvo c70 t5, will do 30mpg at a push. I think your right foot might be a bit on the heavy side! I've averaged in excess of double that towing the MG behind my 20v NA V70 (basically same engine as the T5 but without the blower). If you ever travel down Bristol way let me know and I'll have a chat with my friendly metal supplier (who's also hot, into Minis and sadly spoken for) and see if I can sort you out with some ally. Isambard Kingdom Brunel said:
17th Jan, 2009 at 05:26:33pm
that was 70mph off the turbo pretty much.
