Home > General Chat > Does anybody know what engine this is?
Tweaked
Member #: 2873
engine number: 10h74368111, i know that the 10h means 1100, but I had a m8 round the other day and he noticed sumthing very interesting about my block, my oil filter is mounted on the far left of the block where he says the coil normally bolts to the motor, i have two motors like this. They both from SA.
interesting....
do the blocks have 2 removable plates on the back of the block?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Is the head 12G940 or 12G202 casting? Maybe theres a chance that its a 1071S. Especially if its from SA
EDIT: actually, 1071S use a Cooper S casting so I don't think it would have the filter there
Edited by GaryOS on 18th Jan, 2009.
On 30th Apr, 2010 Rod S said:
Gary's description is best
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
they 're certainly the 70mm stroke en 16 cranked , 1275 bore, then you're very lucky.
Tweaked
Member #: 2873
not that i have seen
On 18th Jan, 2009 mini13 said:
interesting....
Mr Joshua
Member #: 1954
Luton Bedfordshire
I had a clubman from SA a long time ago think 1990 or 91 and that had me stumped.
Own the day
GaryOS
Member #: 2810
Dublin, Ireland
Wouldn't it have to have tappet chest covers? Choice is between a 1098 which uses a small bore block or a 1071S which uses a Cooper S block. Or could it be a completely wierd engine number and not an 1100 at all?
slater
Member #: 1291
Suffolk / Birmingham
Pictures!
Tweaked
Member #: 2873
have a look in this pic, on the far left u will see the oil filter, i will try get better ones from the other motor tonight
Edited by Tweaked on 19th Jan, 2009.
Is it one of a midget or a moggy minor or something?
Pics of the head and block would be helpful
Sounds like a South African 1100 to me.
They were similar to 1275 Marina blocks with a destroked crank.
If thats the case then they are a good find.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
what is so desirable with them? they are like any 1275 block as far as I know?
Not particularly the block but a short stroke crank is very desirable to some.
miniminor63
Member #: 672
Oslo, Norway
yes, the crank is a nice item, I have one, but I do not see the need for the block, as they only used special pistons, the deck height isnt any shorter.
