| Home > General Chat > OT more Mk3 Golf problems | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
22nd Jan, 2009 at 10:26:51am
Ok i have gone to start the car and i get zip. the car was running fine, i had dropped the missus off at work then did not use it again until 3pm to get the kids from the institute.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
22nd Jan, 2009 at 10:40:54am
Copied from another forum
22nd Jan, 2009 at 10:42:06am
As for the non starting problem. I can remember my cousin having problem on his mk3 vr6 with the starter relay behind the dash failing with dry joints.
Edited by John on 22nd Jan, 2009. If something is worth doing, it's worth doing half of. |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
22nd Jan, 2009 at 10:53:14am
can you not push/bump/tow/roll down a hill start it? Edited by Mini_Andy on 22nd Jan, 2009. |
22nd Jan, 2009 at 10:55:51am
Flat battery?
In the 13's at last!.. Just |
22nd Jan, 2009 at 11:24:04am
well sat for ages with the mothers car jump leads setup and she finally started, left my car running for 45 minutes unhooked the battery from the jump leads went to start it straight away and zilch. what also irritates me is we sat for ages yesterday with jump leads and we could not get it to turn over at all........ the flapping relay IMHO is lack of voltage accross it, i thought 12.6 would be enough to start it but obviously not, so is the battery shagged or is it the alternator or both. with mini's i would know straight away normally with duff alternators the battery warning light pops on.....nothing apparent on the golf will need to borrow a meter to check, i take it with the alternator spinning it should be circa 14v ? and why would it come on all of a sudden.
22nd Jan, 2009 at 11:37:32am
IN02 is simply the service light
22nd Jan, 2009 at 11:49:20am
12.6 at the road side everything off
22nd Jan, 2009 at 11:51:22am
battery could still read 12v but be down on a cell. If something is worth doing, it's worth doing half of. |
22nd Jan, 2009 at 11:56:42am
need to check when running for the alt, but sounds like the batt to me |
22nd Jan, 2009 at 12:20:11pm
cheers guys.....this thread is yet another example of why TM is better than any other forum on the net. i still have had no replies from the alleged enthusiasts on the VAG forum how shite is that !
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
22nd Jan, 2009 at 01:58:40pm
Its current you need to start a car, not voltage (although that also helps) my bets are on the battery, but if the batterys new, could be the alternator not charging it! take it to a local battery place and get it tested! "Cars are a lifetime of pain" |
22nd Jan, 2009 at 02:19:39pm
Totally, you need to do two tests - first a meter on the battery to see the voltage drop when you (try to) crank, if it drops below 10.5v, then the battery is not so good. If it is good, then you need to put the meter between the positive lead on the battery (note, lead, not terminal) and the other one grounded to the engine block. If this voltage drops away, then you have a bad earth (or maybe a bad (+) battery cable).
22nd Jan, 2009 at 02:20:46pm
yeah battery was on the car when i got it, alternator looks really clean so i wonder if that has been changed at some point.
22nd Jan, 2009 at 03:52:44pm
take the battery off and fully charge it. then if you have a drop tester test it with that. should hold it on there for around 10 seconds and it should stayin the green. if it drops out into the red your battery is shagged.
22nd Jan, 2009 at 05:34:03pm
Just got back from the motor factors and a suprise to me too, the battery is spot on, fully charged and he held the tester on for ages and it didnt budge at all
22nd Jan, 2009 at 05:57:50pm
right.
Edited by James_H on 22nd Jan, 2009. |
22nd Jan, 2009 at 08:19:56pm
fucking weird ! tried what you said James and it worked straight away ! I thought great must be a strap so i took the jump lead off and tried it out of curiosity.....the damned thing started up ! i wonder if the removal of the battery has perhaps erset the ecu or something ? i dunno the car is a friggin enigma !
22nd Jan, 2009 at 08:35:28pm
can you pop the switch out?
22nd Jan, 2009 at 09:00:48pm
dude you live too far away from me to know this shit, i command you to move up north and freeze.
22nd Jan, 2009 at 09:03:25pm
haha! its cold enough down here thanks!! |
