| Home > General Chat > Flip Fronts and Light Connections | |||||||
22nd Jan, 2009 at 12:59:33pm
What plugs are peeps using on there lights/wiring for ease of removal of there front end.
50 Posts Member #: 1416 Advanced Member Norfolk |
22nd Jan, 2009 at 01:01:20pm
I used a 7 core (i think) caravan plug
22nd Jan, 2009 at 01:06:50pm
I've got one of these for when I get round to it:
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
22nd Jan, 2009 at 01:12:45pm
just make sure that you check the voltage ratings for the plug for the head lamps etc. i was going to use a Speakon or cannon plug. if it was the latter it would have been a cannon plug per side of the car.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
22nd Jan, 2009 at 01:13:49pm
We used these on the missus' car:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
22nd Jan, 2009 at 01:18:11pm
I used Bosch 4 pin connectors. They type of things you would see on MK3 Golfs etc. They are crap though. I used the proper cripm to put the terminals on but 2 came off. Also, the pins have a habbit of pulling out of the casing.I think I will be using the ones Demon Tweeks sell on my new loom On 12th Nov, 2009 Paul S said:
Gary's description is best |
22nd Jan, 2009 at 01:20:03pm
I used block connectors I got from RS not overly sophisticated for the main loom. For the light connectors and indicator connectors I have swwiched to "Deans Connectors" These are gold plated and cost a couple of quid.
Own the day
22nd Jan, 2009 at 02:43:17pm
oooh the maplin jobbies look nice.
22nd Jan, 2009 at 03:34:31pm
On 22nd Jan, 2009 MikeRace said: Sorry It was Maplins not RS where I got my connectors from
oooh the maplin jobbies look nice. Could be mounted in a panel too. Own the day
1050 Posts Member #: 764 Post Whore Staffordshire |
22nd Jan, 2009 at 04:05:09pm
i used a caravan plug attached to a modified tow bar back plate... Was cheap, tidy and reliable |
22nd Jan, 2009 at 05:24:22pm
On 22nd Jan, 2009 Anton said:
i used a caravan plug attached to a modified tow bar back plate... Was cheap, tidy and reliable That belongs in ghetto mods
Own the day
22nd Jan, 2009 at 06:03:10pm
trailer type plug on mine |
22nd Jan, 2009 at 06:28:46pm
I can't believe you're all using trailer plugs, you might as well chuck some bricks in the boot the amount they weigh, get a proper multi way plug from AutoSpark or Vehicle wiring products. Isambard Kingdom Brunel said:
22nd Jan, 2009 at 08:05:06pm
Can you link to which type you mean? i was thinking the other day it was a bit weighty for no reason. |
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
22nd Jan, 2009 at 08:20:52pm
Army plugs are best, mount a socket to the car and have a plug feeding the front i had loads of problems finding for Vtec but if you look on some car supply pages for kit cars you will find what you need. all sorts of goodies |
22nd Jan, 2009 at 08:34:49pm
Have a look at the ones I linked to above. they weigh next to nothing and are water proof. On 11th Feb, 2015 robert said:
603 Posts Member #: 1938 Post Whore near Dundee |
22nd Jan, 2009 at 08:56:24pm
http://www.iem-services.co.uk/showdetails.asp?id=501
22nd Jan, 2009 at 09:14:56pm
On 22nd Jan, 2009 commander said:
http://www.iem-services.co.uk/showdetails.asp?id=501 what about them? On 11th Feb, 2015 robert said:
22nd Jan, 2009 at 09:24:22pm
On 22nd Jan, 2009 apbellamy said:
That link is just the male half, you will need the female half too.... On 22nd Jan, 2009 commander said: http://www.iem-services.co.uk/showdetails.asp?id=501 what about them? http://www.iem-services.co.uk/showdetails.asp?id=502 |
22nd Jan, 2009 at 09:33:46pm
i use towbar socket seems ok. no longer a series, but still 1.3 turbo.
22nd Jan, 2009 at 09:45:02pm
That link is just the male half, you will need the female half too.... On 22nd Jan, 2009 commander said: http://www.iem-services.co.uk/showdetails.asp?id=501 what about them? http://www.iem-services.co.uk/showdetails.asp?id=502 On 11th Feb, 2015 robert said:
27th Oct, 2009 at 11:55:26pm
right, so pics please, and where did you mount them?
28th Oct, 2009 at 07:12:04am
exactly how mine was joey, had the socket fixed to the bulkhead just to the left of the master cylinders. unplugged it as i lifted the front then took the whole thing off.
28th Oct, 2009 at 07:21:30am
Mines on the drivers side, in whats left of the inner wing behind the cross member. I can reach it easily with the bonnet off. |
28th Oct, 2009 at 08:16:35am
my trailer socket is mounted on the fresh air vent hole (which has been welded over) on the n/s.
