| Home > Technical Chat > Pistons | |||||||
52 Posts Member #: 4982 Advanced Member |
23rd Jan, 2009 at 04:21:57pm
23rd Jan, 2009 at 05:05:38pm
If I'm not mistaken, the Omegas come with a number of different dish sizes, so you've really answered your own question when you say "Assuming the CR....... etc are all OK"
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
23rd Jan, 2009 at 05:15:08pm
CR down = more boost |
23rd Jan, 2009 at 05:15:23pm
The engine that im looking at buying is a 1338cc 9000rpm Screamer with a destroked crank, cooper S rods, IDA weber, APT Cam ,BVH and a metro turbo Cup challenge gearbox.
23rd Jan, 2009 at 05:39:30pm
The fact it has a destroked crank (and the S rods to fit around the smaller journals) suggests it was specifically built, as you say, as a "screamer".
23rd Jan, 2009 at 05:53:05pm
23rd Jan, 2009 at 06:02:55pm
If you plan to change the head and cam, then it would be a goer.
23rd Jan, 2009 at 06:39:28pm
Thanks Paul S, that is exactly what i needed to know!
23rd Jan, 2009 at 06:46:58pm
The only thing I would add (if you haven't actually bought it yet) is to find out what cc (dish size) the current pistons are.
23rd Jan, 2009 at 07:07:03pm
Rod is quite right.
23rd Jan, 2009 at 07:25:20pm
Ive just spoken with the seller. He reckons that they are a 7c dish.
23rd Jan, 2009 at 07:36:29pm
I would suggest you start from scratch, decide exactly what you want the end result to be, and do your "shopping" once you have decided.
23rd Jan, 2009 at 07:51:54pm
Yeah cheers Rod.
23rd Jan, 2009 at 07:52:47pm
On 23rd Jan, 2009 B15MJO said:
Ive just spoken with the seller. He reckons that they are a 7c dish. To be honest hes advised againsts turboing the engine because of the small crankshaft, hes also recommended forged pistons but freely admits that he doesnt know much about FI. You are still going to be above 9:1 with a 30cc chamber head. I would go with that, provided you use something like a GT1752 turbo and an efficient intercooler placed in a good airflow. At the end of the day, it is charge temperature that causes piston damage, rather than compression. If the crank can handle 9000 rpm, it will be fine with forced induction at say max 7000rpm. Loadings under forced induction are compressive whereas with a high revving NA engine the loads are tensile and more destructive. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Jan, 2009 at 09:25:27pm
Would it not be easier to start with a standard block and build it to exactly what you want?
24th Jan, 2009 at 10:19:09am
The value is in the gearbox and the bits he can sell.
24th Jan, 2009 at 12:47:09pm
What do you reckon the gearbox is worth? My plan was to keep the gearbox and straight cut drop gears x pin diff , and sell the engine on with a STD gearbox for as close to the £1000 as i can.
24th Jan, 2009 at 01:34:29pm
To rebuild a box with new bearings, straight cut drops and gears and a x-pin diff would cost close to a £1000. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Jan, 2009 at 01:50:11pm
I think you will have issues using this engine,
24th Jan, 2009 at 01:56:09pm
Cheers mini13. That was my intention.
24th Jan, 2009 at 05:16:01pm
I've got one of those. If something is worth doing, it's worth doing half of. |
24th Jan, 2009 at 11:41:27pm
How is the box minimadmotorman? is it any good? Whats the spares availability like? Are the ratios suitable for road use as ive been told that 1st gear is extra long.
