| Home > Help Needed / General Tech Chat > Pre Verto.......... | |||||||
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
23rd Jan, 2009 at 06:00:55pm
Hi just had my new engine back, pre verto clutch now could you tell me if Ive fitted this correct? Spring to nipple
Edited by MiniTurboBadBoy on 23rd Jan, 2009. |
23rd Jan, 2009 at 06:01:08pm
23rd Jan, 2009 at 06:11:26pm
chris, there should be a small bracket which the nipple holds on and then a small hole where the spring locates on the bracket buddy
23rd Jan, 2009 at 06:12:01pm
23rd Jan, 2009 at 08:19:53pm
I never fit the spring. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
23rd Jan, 2009 at 09:01:25pm
Wrong in photo....
24th Jan, 2009 at 11:35:08am
Cheers guys do you know if you can get this bracket that sandwiches in betweeen the nipple? none on minispares.com. Or will I have to make one?
Edited by MiniTurboBadBoy on 24th Jan, 2009. |
24th Jan, 2009 at 12:30:32pm
On 24th Jan, 2009 MiniTurboBadBoy said:
Cheers guys do you know if you can get this bracket that sandwiches in betweeen the nipple? none on minispares.com. Or will I have to make one? Chris mine came with the new slave but it could be made out of a bit of sheet steel in about 10 mins Yes i moved to the darkside |
24th Jan, 2009 at 12:49:18pm
Item 64 on Moss here but no longer available...
Edited by Rod S on 24th Jan, 2009. Schrödinger's cat - so which one am I ??? |
24th Jan, 2009 at 12:52:40pm
What about the small 1/4" UNF bolt down on the clutch arm. I cannot see it...Is it there? On 13th Jul, 2012 Ben H said:
24th Jan, 2009 at 01:01:28pm
Piccy (of a rather rusty one...)
25th Jan, 2009 at 10:30:16pm
Thanks all! Think I will have a go at making that looks easy engough. |
