Home > General Chat > Lambda placing
Alex1340
Member #: 111
Loughborough
I'm going to weld the boss in to me exhuast tomorrow. How far down the pipe should I put it? Has any one found a good way to fit them in with out fouling on anything?
Is it wide band or narrow band?
I believe that wide band should be near the bottom of the down pipe where it is cooler, whilst narrow band should be closer to the turbo.
Hopefully someone will correct me if I got that wrong.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
I would agree with Rob H on this one.
If narrow band, assuming T3, 4 inches or so from the elbow joint, pointing at right angles to the engine, toward the drivers side tower. this will allow access to the sensor, and protection for it by the bulkhead.
Regards
Colin
Nick
Member #: 154
Midlands
my widebands in the link pipe by the gear selector box to make running the wires inside easier.
you dont really want any lambda sensor too close to the turbo. if the sensor tip gets red hot its as good as a nose up your arse.
and seeing as some of the set-ups get a right glow on after some spirited driving.
i would say any sensor should be no closer than in the second half of the downpipe.
as long as you dont have any blows pre-lambda the reading wont change much.
Monkeh
Member #: 1997
Lichfield
according to the instructions that came with my STACK wide band sensor "Turbocharged applications should have the sensor installed 100-125 mm after the turbo on the down pipe"
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I seem to remember Rod S asking the same before and he found it difficult to get a straight answer. 150mm is rining a bell with me as a minimum though. Don't forget that you can buy or make a heat sink if your concerned about heat.
Your running a SC aren't you? Heat wouldn't be as big a concern then
On 30th Apr, 2010 Rod S said:
Gary's description is best
1972-ANGUS
Member #: 3894
are there many sc's in ireland spanner?
GaryOS
Member #: 2810
Dublin, Ireland
None that I know of. Theres nobody on here and I've never heard of one or seen one at a show. We are farr too automotively underdeveloped. Theres very few cool cars over here *frown*
Coupe
Member #: 2178
Leyland, Lancs
You've got more AE86's than we have though!
I did, and you are right - a wide (forgive the pun) variation in opinions.
In the end I went through all the usual suppliers' instruction sheets (where I could access them on line) and found they all varied with little reference to turbos and I don't remember any of them talking about SC *frown*
So I located the Bosch data sheets (most wideband LSUs are Bosch) and found it came down to TWO temperature limits, one for the body of the sensor (ie, the housing of the cell) and one for the exhaust gas itself (ie, the gas going into the cell).
The most common quoted interpretation of these two temperatures was a minimum of 300mm from the nearest exhaust valve on N/A or a minimum of 300mm from a turbo outlet.
You can, as Spanner says, use a heatsink (sandwiched between the sensor and the welded boss) to deal with excessive body temperatures, and you can use an extended boss to take the probe tip into a cooler part of the gas stream, ie, put the tip up inside the boss, but this slows reaction time.
That is what I read anyway.
Note, the Bosch data made it clear that the figures quoted were to achieve a 100,000 mile life and that higher temperatures, ie, closer to the valves or turbo doesn't necissarily stop it working, it just reduces the life.
As you are running an LCB, you need to put it in the link pipe.
Alex1340
Member #: 111
Loughborough
Yeah its a LCB so needs to go after the Y section but worried about hitting the floor.
It's tricky to get right.
They recommend that you do not go below the horizontal as it could collect moisture, but if you don't it will hit the floor.
Just get it as high as you can and on the drivers side.
