| Home > Help Needed / General Tech Chat > MEMS 2J & Supercharging | |||||||
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
23rd Jan, 2009 at 09:50:04pm
Ok, second posting on the forum and it might be a stoopid question, but someone once said to me
Edited by MrOz on 23rd Jan, 2009. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
23rd Jan, 2009 at 10:07:48pm
I have heard this a few times before, and, while the theory may stand up, I dont think it would work. Infact I know some one who tried it and it didnt work.
Edited by Sprocket on 23rd Jan, 2009. On 26th Oct, 2004 TurboDave16v said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
23rd Jan, 2009 at 10:10:26pm
On 23rd Jan, 2009 Sprocket said:
I have heard this a few times before, and, while the theory may stand up, I dont think it would work. Infact I know some one who tried it and it didnt work. The theory is, as with any Mini EFi supercharger set up, the fuel is injected before the supercharger, therefor you could use the vacuum between the throttle body and the supercharger for the MAP sensor on the MEMS2J ECU and fuel the engine. The problem is that with the supercharger you are moving away from the MPi calibration. then there is the acceleration enrichment, there just wont be enough, not even close. add to that the difference in charge air densities. Buy a programable ECU and do it properly, it would be a lot less time consuming trying to work around the production ECU ![]() Second that motion. regards colin |
30th Jan, 2009 at 10:55:26pm
I have heard this a few times before, and, while the theory may stand up, I dont think it would work. Infact I know some one who tried it and it didnt work. The theory is, as with any Mini EFi supercharger set up, the fuel is injected before the supercharger, therefor you could use the vacuum between the throttle body and the supercharger for the MAP sensor on the MEMS2J ECU and fuel the engine. The problem is that with the supercharger you are moving away from the MPi calibration. then there is the acceleration enrichment, there just wont be enough, not even close. add to that the difference in charge air densities. Buy a programable ECU and do it properly, it would be a lot less time consuming trying to work around the production ECU ![]() Yeah, it has been suggested that I plump for a Emerald, Megasquirt or CAMEMS ECM, but I'd prefer to retain MEMS. It's not just a cost factor, well it is cos I'm tighter than a Nuns box, but I'm using this as a research project for my studies. With regards to MAP, I was thinking about the possibilities of inverting the MAP signal, but I'm still not convinced that this won't result in a lean mixture. I dig what you say about the enrichments Sprocket - might need to pull the draw string on the thinking cap a bit tighter. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
30th Jan, 2009 at 11:49:47pm
It just wont work, but feel free to try it.
