| Home > General Chat > Dumbass question..... | |||||||
25th Jan, 2009 at 06:15:40pm
Whats lighter water or titanium?
I seriously doubt it! |
25th Jan, 2009 at 06:21:05pm
ti is 4.5 times the weight of water IIRC On 28th Aug, 2011 Kean said:
25th Jan, 2009 at 06:21:52pm
Water by a long way.
25th Jan, 2009 at 06:28:51pm
Ah Ah the cat is out of the bag, Paul is making a solid Titanium radiator...
25th Jan, 2009 at 07:41:21pm
Put it the other way around... "what's heavier, water or titanium?"
25th Jan, 2009 at 07:44:06pm
On 25th Jan, 2009 giallofly said:
Ah Ah the cat is out of the bag, Paul is making a solid Titanium radiator... No water, less weight! Why did'nt I think of that! JF. Thats a bit of a misnomer. what you sugest would make the car heavier, wich not always a bad thing
25th Jan, 2009 at 07:48:13pm
On 25th Jan, 2009 Rob H said:
Water by a long way. Specific mass of water is 1 whist TI is about 4.5. As an aside steel is about 8 and aluminum is about 2.5 useful to know when working out weight savings. 1kg of water is 1 litre and a specific gravity of 1. everything else is compared to water
25th Jan, 2009 at 08:07:54pm
Actually I'm pretty sure that a ton or water weights the same as a ton titanium. Isambard Kingdom Brunel said:
25th Jan, 2009 at 08:15:39pm
Actually I'm pretty sure that a ton or water weights the same as a ton titanium. Tonne or ton?
25th Jan, 2009 at 08:18:51pm
If titanium has a SG of 4500 kg/ cu.m and water has a SG of 1000 kg/ cu.m which is heavier? On 26th Oct, 2004 TurboDave16v said:
315 Posts Member #: 3013 Senior Member Epsom Surrey |
25th Jan, 2009 at 08:20:09pm
but if 1 tonne weighs the same as the other what about the container that will hold the 1 tonne of water?? |
25th Jan, 2009 at 08:21:16pm
it does, but the water is 4.5 time bigger....
Actually I'm pretty sure that a ton or water weights the same as a ton titanium. On 28th Aug, 2011 Kean said:
25th Jan, 2009 at 08:24:17pm
Which is heavier one tonne of feathers or one tonne of coal? On 26th Oct, 2004 TurboDave16v said:
25th Jan, 2009 at 08:38:15pm
On 25th Jan, 2009 Sprocket said:
Which is heavier one tonne of feathers or one tonne of coal? On 17th Feb, 2009 Rob H said:
25th Jan, 2009 at 08:51:01pm
On 25th Jan, 2009 PaulH said:
the answer to this is so blody easy Colin I realy suprised you dont know I mean it has to be the sheep
On 25th Jan, 2009 Sprocket said: Which is heavier one tonne of feathers or one tonne of coal? Shawn or Wooly sheep? Is there something you want to tell us about yourself and the exploits of sheep. Perhaps you can team up with Jimster
25th Jan, 2009 at 09:19:27pm
If titanium has a SG of 4500 kg/ cu.m and water has a SG of 1000 kg/ cu.m which is heavier? depends on how much of each you have. |
25th Jan, 2009 at 09:54:06pm
OK this is where Mass and Weight start getting confused On 26th Oct, 2004 TurboDave16v said:
25th Jan, 2009 at 09:55:00pm
at the end of the day, weigh them and find out!
25th Jan, 2009 at 10:03:04pm
All the info you would ever need is in this topic about the initial question On 26th Oct, 2004 TurboDave16v said:
25th Jan, 2009 at 11:27:53pm
What do you mean team up the man is my mentor
On 25th Jan, 2009 Sprocket said: :$
On 25th Jan, 2009 Sprocket said: Which is heavier one tonne of feathers or one tonne of coal? Shawn or Wooly sheep? Is there something you want to tell us about yourself and the exploits of sheep. Perhaps you can team up with Jimster ![]() On 17th Feb, 2009 Rob H said:
52 Posts Member #: 4982 Advanced Member |
26th Jan, 2009 at 08:32:47am
Whats heaver? A ton of sand or a ton of feathers? |
204 Posts Member #: 5022 Senior Member Oxford, Kings Lynn, Pod, Pub. |
26th Jan, 2009 at 07:28:18pm
Water is lighter than Ti,
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!! |
26th Jan, 2009 at 07:32:57pm
On 26th Jan, 2009 SidewaysGTM said:
Water is lighter than Ti, Ti is grey and Water is clear!!! WEST A dumbass question gets a dumbass answer Paul I seriously doubt it! |
27th Jan, 2009 at 01:10:15am
both the same, but if it was a tonne of sand and a long ton of fethers then...
On 26th Jan, 2009 B15MJO said:
Whats heaver? A ton of sand or a ton of feathers? Edited by Paul R on 27th Jan, 2009. Drives
27th Jan, 2009 at 01:51:52am
Does the "ton" "Tonne" thing piss anyone else off? The words are completely redundant in conversation as nobody call tell which one you said On 12th Nov, 2009 Paul S said:
Gary's description is best |
