| Home > Help Needed / General Tech Chat > which clutch | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
27th Jan, 2009 at 01:24:36pm
I have just had my clutch go after 6 months of use spread over a year (car on and off the road a fair bit you see) the clutch that is in it is the one med supplied me and they list as a turbo clutch cover and plate this is a verto setup
"Tuning should be a compromise between what is possible and what is necessary"
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
27th Jan, 2009 at 02:02:31pm
speak to stuart gurr, or have a look at roberts clutch setup! "Cars are a lifetime of pain" |
27th Jan, 2009 at 02:13:11pm
Some one needs to try out some of these new verto units. You look like the ideal candidate.
27th Jan, 2009 at 02:19:55pm
The guy from Min-Its told me about this clutch at Stanford Hall show and quoted a clamping pressure that I instantly forgot - it's an age thing!
Edited by Paul S on 27th Jan, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Jan, 2009 at 02:34:46pm
Are the clamping pressures of all the different clutches listed any where that would be a realy useful faq if not, comparing the vertos and the pre-verto
27th Jan, 2009 at 02:40:43pm
On 27th Jan, 2009 turbominij said:
Are the clamping pressures of all the different clutches listed any where that would be a realy useful faq if not, comparing the vertos and the pre-verto No, but it is available from Mini13 On 27th Jan, 2009 turbominij said:
and is this min- its clutch up to the job it says it is? You are just the man to find out. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Jan, 2009 at 02:43:14pm
Apologies, just read your first post again.
27th Jan, 2009 at 02:43:38pm
27th Jan, 2009 at 02:47:11pm
On 27th Jan, 2009 Paul S said:
You are just the man to find out. i would but i realy dont have £120 to just bin if it dont (i might have to lo) also this med one is intersting they said it would cope with power anything up to 15psi would produce "Tuning should be a compromise between what is possible and what is necessary"
27th Jan, 2009 at 02:51:32pm
also this med one is intersting they said it would cope with power anything up to 15psi would produce Get them to confirm that it will handle 180 lbft of torque then. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Jan, 2009 at 03:05:23pm
The 'peak' clamping pressures alone don't tell the full story. The 'return' force is the one that is important (ie the force from over-centre to clamp), together with the clamping pressure over a range you are interested in - ie between a brand-new plate and one just about down to the rivets.
Edited by turbodave16v on 27th Jan, 2009. On 17th Nov, 2014 Tom Fenton said:
27th Jan, 2009 at 03:40:49pm
I really like the idea of these new verto setups.
In the 13's at last!.. Just |
27th Jan, 2009 at 05:29:58pm
so do you guys recon i am going to need to convert to pre-verto setup then ?
27th Jan, 2009 at 05:32:26pm
so do you guys recon i am going to need to convert to pre-verto setup then ? Either that or make yourself a double spring verto. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Feb, 2009 at 10:58:14am
I decided to go down the pre-verto route as i wanted something that i could get parts for easily with out having to build up a new double clutch every time it needed changing.
