| Home > General Chat > Choke Seals from HIF NA | |||||||
27th Jan, 2009 at 02:44:26pm
Are the Choke seals from an NA HIF any different from the Seals on a HIF Turbo??? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th Jan, 2009 at 07:25:13pm
I'm pretty sure that they're the same. Isambard Kingdom Brunel said:
444 Posts Member #: 2885 Senior Member |
27th Jan, 2009 at 10:09:01pm
So then why will the throttle seals need to be any different?
27th Jan, 2009 at 10:49:31pm
Turn the choke seals the other way round for N/A. I think theres 2 different sizes too. On 19th Jan, 2010 wil_h said:
28th Jan, 2009 at 07:48:57am
Can i test the choke whilst i have the carb off the car.
28th Jan, 2009 at 07:54:16am
Even N/A carbs are pretty well sealed as they have to deal with vacuum. In reality using an unmodified HIF or SU for a turbo application is perfectly feasable.
28th Jan, 2009 at 08:37:21am
Hmm, theres something a miss with my motor, i was having massive overfuelling problems even with the mixture screw screwed right in! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Jan, 2009 at 08:52:12am
Have you checked your fuel pressure? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Jan, 2009 at 09:11:07am
Yeah, 4.5psi on idle. Its built inline to my carb. Edited by MikeRace on 28th Jan, 2009. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Jan, 2009 at 08:29:16pm
But does it rise with boost? |
29th Jan, 2009 at 08:43:56am
Hmm dunno, i havent checked, the reason being is that the car drives perfect. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
