| Home > Technical Chat > 6mm race valves | |||||||
27th Jan, 2009 at 04:27:22pm
Hi lads I know these aren’t really Turbo talk but as always some one on here has come up agents this problem. I am running a set of 6mm valves in this years 1380 race engine I got the valves, caps and retainers, from Paul Ivey but he no longer makes the little buckets to go on top of the valve, to stop the rocker popping off. Has anyone fitted these and found a solution I was thinking of turning them off from silver steel and just heat treating them? On 17th Feb, 2009 Rob H said:
27th Jan, 2009 at 07:02:02pm
MED and Swiftune? They do indeed sell the 6mm stuff...
27th Jan, 2009 at 09:00:36pm
see this sight is realy the Fucking dogs bolix thanks V On 17th Feb, 2009 Rob H said:
