Home > Help Needed / General Tech Chat > Picture request please
I am having a little difficulty i hope someone can help me with, i bought a maniflow side exit on sunday, i am fitting it to my clubby for now maybe the roundy later when it goes on the road, both currently have a centre exit system and wondering what sort of mountings you guys are running at the tale pipe end, any advice welcome
Cheers, Brett
Minispares do a bracket that mounts to a couple of bobbins on the rear frame as part of the RC40 fitting kit; alternatively you can bugger about with a centre bracket and a single bobbin but I've always found they don't last well
Like this:
There's a triangular bit of steel attahced to one bobbin in the subframe standard exhaust mount hole.
Before I get any comments. I'm using a hose clamp because standard pipe clamps/U Bolts scrape on speed humps. This has done over 1000 miles and hasn't needed to be tightened yet... D:
EDIT: last time I looked it had a nut on the outside of the bobin too *surprised*
Edited by apbellamy on 27th Jan, 2009.
cheers guys
