| Home > Help Needed / General Tech Chat > Turbo exhaust elbow | |||||||
172 Posts Member #: 1600 Advanced Member Portsmouth, Hampshire |
27th Jan, 2009 at 08:59:24pm
just picked up mini t3 on mani's etc, and the elbow has had a hole in it at some point, possibly 3mm hole.
444 Posts Member #: 2885 Senior Member |
27th Jan, 2009 at 10:16:04pm
Brazing will not be strong enough I think. |
27th Jan, 2009 at 10:22:24pm
uhmm if it gets nice and toasty (red hot is known/common!) could the brazing not start to melt?
27th Jan, 2009 at 10:24:47pm
Brazing is not allowed for body repairs for an MOT now if that gives you an idea soontobe man
27th Jan, 2009 at 10:53:01pm
hmmmm, bad times.. did wonder about the heat, but that proves it.. cant be to hard to source another,
27th Jan, 2009 at 10:55:53pm
you could possible get it drilled out and a boss welded in there for a wideband. then you can just run the blanking plug in the boss.
Edited by James_H on 27th Jan, 2009. |
4th Feb, 2009 at 01:26:00am
when you send it to me i will weld it up and sort it for you
