Home > Help Needed / General Tech Chat > none starter
Nick
Member #: 154
Midlands
having some trouble getting my engine to start...
its a new engine so it hasn't run before. it's defiantley got a spark at the plugs and the fuel is getting in there fine, although i think it may be too much.
I've set the fuel presure at 3.5 psi, and the only thing that has changed from the last engine as its the same carb is that i've blocked off the balance pipe and fitted a dump valve.
We've checked the timing and it seems to be in the right sort of place, probably not exact but it should run even if it runs shitty.
Anyone got any idea's? i dont really want to start messing with the mixture until its running. I might just take the plenum off and try and start it with just the carb incase there's something causing a restriction in the airflow? maybe?
Cheers, Nick.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
have you got sparks?
have you got fuel?
alex
AlexF
Nick
Member #: 154
Midlands
yep, im just about to try swapping the dizzy drive round incase thats in wrong.
Nick
Member #: 154
Midlands
woohoo. it feckin runs :) the dizzy drive was quite a way out :) started on the nose after that. all i need now is some pressure in me brake pedal and it can go for a roper drive :)
