Home > General Chat > Sports Libre Hillclimb Class
advantage998
Member #: 1840
Kings Lynn, Norfolk
From what i can work out this is what class i will have to be in due to the composite roof, please correct me if i am wrong.
This class has a limit of 2000cc cars so there gonna be pretty quick.
So i need to start spec-ing up a suitable engine. With a turbo'd 1380 that would class it as 1932cc, so is this the way to goto make the power required?
As you can tell i'm pretty new to this, will be speaking to a few engine builders in the next few weeks, but wanted to hear your oppinions first.
Thanks Guys, Tom
Ben H
Member #: 184
Melton Mowbray, Pie Country
If you have a composite roof then you it will be sports libra. Also anything greater than a 1000cc turbo will also put you in sports libra. Unfortunately this is a catch all class so it can be anything, single seaters, kit cars, space frames, etc. Being competitive in a mini will not be easy.
It is all about having fun though so give it a go.
http://www.twin-turbo.co.uk
Tom, if your planning on hillclimbing you may be up against me, ive obviously got to go in sports libra ,abd yes its against loads of big and powerfull stuff.
I arn't realy planning on being that competative but it will be nice to be there with the atmosphire im my car.
Rick
AllanMcD
Member #: 414
Dalbeattie Scotland
What meetings do you boys plan doing?
I do the auto66 club meets and a few random British hill climbs Sports Libre mini.
Allan
http://www.rabdunn.co.uk/
MarkGTT
Member #: 1194
Shropshire.
Im thinking of doing a few events (just for fun) this year. Will have to wait and see, as like you Tom, i don’t have a clue about it (no offence intended)
Coupe
Member #: 2178
Leyland, Lancs
Is any specialist equipment required to have a go in this class? I don't have a cage in the car at the moment (well I don't have much in the car at the moment!) and there may not be one going in, but I'd like to have a go at something like this.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Ok so sports libra it is then, from what i can tell there are no engine restrictions??
Rick that sounds like a good bit of fun at least we'd be able to compare againsts each other.
Still only at the planning stage for what championships to compete in as i can't really work out what i'm elligable for.
No offence at all Mark, i stick my hands up and admit i'm completely baffeled by all the rules and regulations.
The other question which i'm not 100% sure about is, in the sports libra i'm thinking the new fuel sampling regulation applies, so i'll need a dry break coupling?
advantage998
Member #: 1840
Kings Lynn, Norfolk
Coupe, from what i have worked out sofar you can run anything from a standard road car up to a full out racer. Obviously helmets and overals are required and to a certain standard.
The blue book is totally thickle, your best option is to join you local motorclub and start talking to people about what they're running and what you're building, also as most sprints are closed to the public (mostly due to the cost of public liability insurance) you might want to volunteer to do a bit of marshalling, a good way to get your foot in the door so to speak.
Ben H
Member #: 184
If you haven't already have a look here:
http://www.hillclimbandsprint.co.uk/home.asp
There is a good beginners section: http://www.hillclimbandsprint.co.uk/allabout.htm
One more thing on sports libra, I recall if it is over 2000cc you need an A license, so be carful if you are a beginner on a B license. Also I think you will need a cage so coupe I think you will need a cage as I can't see another class that you fit into.
Rob H, what sprints do you go to? The only one closed to the public that I know is MIRA and that is for totally different reasons.
edit, you won't need a dry break coupling unless you have injection.
Edited by Ben H on 4th Feb, 2009.
It's the little ones on airfields where they don't seem to let the public in, Colern springs to mind.
Ben H
Member #: 184
All ours (apart from already mentioned MIRA) are open to the public. Here is a list of events and classes. Pop along to a couple and see what you think.
http://www.hillclimbandsprint.co.uk/calendar.htm
advantage998
Member #: 1840
Kings Lynn, Norfolk
Cool thanks for all the advice. Will certainly be checking out a few events.
Have already enquired about marsheling, but at the moment its not really possible due to working most weekends.
Hedgemonkey
Member #: 360
The sports libre class around here has a Maguire Spaceframe mini which is very competetive, a fiat twincam Minor Turbo, which is faster than most. Sports Libre is the most interesting class, sadly, there are things like Mallocks, which make it almost pointless competing. They should be in Single Seaters.....
AllanMcD
Member #: 414
Dalbeattie Scotland
You cant win them all *frown* just cool a bit and dont worry about the super fast cars you cant beat.
Allan
Ben H
Member #: 184
Unfortunately it is a catch all and will never be a competitive class. it all comes down to the major rule of building a race car. Don't build the car you want, first find a competition you like and build a car to their rules. Otherwise you end up with a car and no one to race against.
Scruffy
Member #: 328
Seaford Rise, South Australia
1 word for sports libre class
6r4
heres another two twin turbo!
On 5th Sep, 2011 Vegard said:
Talk like that is no good without pictures?
Ben , any chance of a link to regs for the class, ive got a 2006 blue book but carnt find anything specific.
Will mentioned a road class? id like to no things like what extinguisher do i need, and if things like that vary depending on road class,or race?
Rick
Scruffy
Member #: 328
here you go Rick
Scruffy
Member #: 328
And here is what he uses when the 6R4 is broken!
Thanks nick.
Does or did the metro run at brighton? remember seeing a twin turboed one there other year. There was a red one at shelsley last year aswell.
Rick
Scruffy
Member #: 328
Don't know got pissed off with Brighton after they put a Busa engined Westfield in the upto 1400cc modified production class
Ben H
Member #: 184
It really depends on what championship you race in. Our class structure is like this: http://www.hillclimbandsprint.co.uk/calendar.htm so you would end up in class F. In the blue book you need to look at section 'I', in there is a section on sports libra. Once I get my 2009 book I can post you my 2008 book with a few sections highlighted. You will need a roll cage and harnesses, but not an extinguisher.
*surprised* looooooooovvvvvvveeeeee it!!!
Twat Twat Twat Twat
Ive been doing some more digging on the rules of the sports libra.
Wel basicly i carnt use my mini in hilclimbs. my main roll over hoop has to be made from seamless tube to a certain size, guess what ? mine isnt*frown* Im gutted.*frown*
Rick
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
