| Home > Help Needed / General Tech Chat > Turbo using a Weber, anybody had any success? | |||||||
74 Posts Member #: 72 Advanced Member |
28th Sep, 2004 at 02:24:06pm
I turbo'ed my mini using a weber 42 carb and it worked until 4000 rpm then it doesnt get any fuel. I guess this is because the engine sucks fuel from the carb but with boost the air is forced through the carb and therefore doesnt grab any fuel on the way through. |
28th Sep, 2004 at 02:35:27pm
Sounds like the fuel pressure regulator isn't working/st right or the fuel pump isn't up to the job.
29th Sep, 2004 at 06:48:26am
First of all, do you have all the necessary ingredients for the blowthru turbo recipe ? Like boost referenced fuel pressure regulator, return lines etc ?
29th Sep, 2004 at 06:50:04am
Forgot another thing: naturally if your jetting is way off you get the same problems.
29th Sep, 2004 at 11:24:22am
Its a DCOE, when I get home I'll take note of all the choke sizes etc.
Edited by MajicMini on 29th Sep, 2004. |
29th Sep, 2004 at 11:52:30am
The fuel pressure regulator needed is one specific to a turbo application. It increaces the fuel pressure as the boost increases. Basically you need the fuel pressure 3-5psi above boost pressure otherwise no fuel will get out of the float bowls.
29th Sep, 2004 at 12:10:09pm
Easiest way is to think of an SU.
Edited by turbodave16v on 29th Sep, 2004. On 17th Nov, 2014 Tom Fenton said:
29th Sep, 2004 at 12:40:33pm
Thanks guys, it has given me a clearer understanding.
62 Posts Member #: 198 Advanced Member |
29th Sep, 2004 at 02:23:36pm
I have weber 45 an I found It needed new gaskets (Top cover, cap etc) to make it air tight, an overhaul kit might be good if its an old one.
29th Sep, 2004 at 03:08:03pm
Mine has been sealed perfectly, It was all rebuilt. |
29th Sep, 2004 at 04:56:22pm
Then you should have no problems, best of luck |
29th Sep, 2004 at 06:02:34pm
Guys have covered most of it but 1) you need to pressurize the float chamber via the vent hole and 2) you need the boost referenced regulator (whatever the carb in blowthru setup, you still need one).
29th Sep, 2004 at 06:29:46pm
Thanks guys, you've been a great help, I will keep you guys updated with how it comes along :) |
28 Posts Member #: 773 Member Kaneohe, Hawai'i, USA. |
22nd Feb, 2006 at 05:25:01pm
Hmmm... sounds like my best bet would be to just pick up a metro turbo carb and go from there. |
64 Posts Member #: 947 Advanced Member New Zealand |
22nd Mar, 2006 at 09:35:18am
i am using deloters (almost the same as webers. They pull hard right the way thru the rev range. Only problem is sometimes the engine dies when the throttle is closed and the clutch is in Caution !!!! Slippery when boosting |
24th Mar, 2006 at 09:51:07am
staggy ,you may find this is caused by the vrief surge of boost against the closed butterflys in the carb ,pushing a bit more fuel than normal down the idle jets ,this give a flash of rich mixture that can make the engine cut , ,this is only if yuor blowing through the carb ,if yours is the red suck thru one i saw on here ,it could well be cos your condensing effect of the intercooler is causing the fuel to drop out ,and lay on the intercooler walls ,so not getting to the cylinder ,and so giving a brief lean effect .
24th Mar, 2006 at 10:00:20am
magic mini, where you take the signal for the boost to the float chamber ,will have a direct effect on your jetting ,.if you take it form a point where the air is turbulent ,you may find it hard to get consistent carburation .if you can find a dynamic take off point ,pointing into the airstream ,eg on the outside of a bend ,you can find sometimes that you wont need to change jetting v much if at all ,this is because as the boost and airflow rise ,you get an artificially high fuel pressure rise , that increases with air velocity ,so compensating for the air density increase. you can also take it off before the intercooler ,and so get another dimension of pressure ratio increase ,since pre ic the boost is a little higher ,and this diff in boost will increasec as rpm goes up and the ic becomes more restricting ,this is omly true if using a tooo small ic ,as seems to be the case on most turbo mins. due to the bloody things having such a cramped engine bay.lol
24th Mar, 2006 at 10:28:16am
On 22/03/2006 09:35:18 Staggy said: '
i am using deloters (almost the same as webers. They pull hard right the way thru the rev range. Only problem is sometimes the engine dies when the throttle is closed and the clutch is in Deloters? Damn, that was new :) Dellortos possibly?
24th Mar, 2006 at 10:31:43am
On 24/03/2006 09:51:07 ivanhoew said:
staggy ,if yours is the red suck thru one i saw on here ,it could well be cos your condensing effect of the intercooler is causing the fuel to drop out ,and lay on the intercooler walls ,so not getting to the cylinder ,and so giving a brief lean effect . regards robert. I find this interesting, I thought that an intercooler on a suckthrough was a no-no. It's certinally the only suckthrough system I've ever seen with an intercooler. You're running funny fuel though iirc? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Mar, 2006 at 06:40:12pm
it is an intercooler. it proboalby is not very efficient where it is. Might need to be moved. Surely it would have a cooling effect. The car also runs water/meth injection after the intercooler.
24th Mar, 2006 at 06:42:11pm
What are the reason for no intercooler. ??? Caution !!!! Slippery when boosting |
24th Mar, 2006 at 08:58:54pm
I've jsut heard on another forum of a chap who saw the intercooler on a 'suck through' turbo instalation explode on a drag-strip...
25th Mar, 2006 at 06:52:58am
well it seems to work. I will test it out on the dyno with the IC remvoed and see what happens and report back. I didn't build the car but it seems to work ok. A cooler fuel/air mix has to be better.
29th Apr, 2006 at 07:16:43am
Well the intercooler has been removed today and a new manifold made up. And guess what you guys were right. The car runs heaps smooth, doesn't stall on off throttle and i have even been able to turn the idle way down. I measured the pipe work i had before and it was well over a meter long. The new manifold is only 25cm. The boost has been turned down until the water/meth system is all sorted. Thanks for the help everyone Caution !!!! Slippery when boosting |
29th Apr, 2006 at 08:54:08am
Glad to hear it has worked well for you, it is interesting for someone to be able to prove the theory that an intercooler on a suck through system is a no-no.
