Home > General Chat > Intresting Trigger wheel
Not sure where to put this as I'm not selling them but, Looks like a very cheap alternative. Love to see one in the flesh but at this price its got to be worth a punt..
http://trigger-wheels.com/store/index1.html
advantage998
Member #: 1840
Kings Lynn, Norfolk
I've also had one of the ones sprocket pictured above, did the job perfectly, good quality laser cut teeth and naff all money, Only chnaged it due to getting a specialist component set up.
I think I know what Graham means (but the link doesn't work properly). If you go to the Trigger-wheels (.com) site and go to the "Engine specific trigger wheel kits" they now do one specifically for the A series with a built in centre so it fits with the main crankshaft tail bolt. It's obviously new, I only spotted the other day when searching for some connectors.
Coupe
Member #: 2178
Leyland, Lancs
I got a very similar one off mini-marauder on here last year - haven't fitted it yet though - need to have my pulley machined down first to accommodate the wheel.
G13B
Member #: 1376
Here´s mine, machined, and bolted to an underdrive pulley, sloted holes for the fine tuning*wink*
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have not seen those before, well from them anyway. Looks nice for the money.
http://www.twin-turbo.co.uk
Rod, Sorry thats what I mean. This is a new kit that someone on TMF has just ordered they say no machining required a bolt-on type like mine but on the other side. For £39.99 if its as good as they say its cheap.
Oh your are right the link doesn't work properly when you copy it.. you need to do what Rod explains below. Its engine specific link and then Aseries.
hario
Member #: 2885
The trigger wheel is sprockets photo appears to have two missing teeth opposite eachother ala' some french car I forget..
Thats because its for an SPi set up *wink*
hario
Member #: 2885
Oh, cool.
They should have an series specific sensor bracket by the end of next week for £19.99
got any pics
No. I just emailed them for a price. I'll be getting mine from ben as it's specific (ish) to the SC12 kit...
