| Home > Beginners Tech > immature, beginner, what ever you call it questions | |||||||
547 Posts Member #: 2928 Post Whore peterborough |
3rd Feb, 2009 at 11:02:05pm
just few quiries
Jack Jones |
3rd Feb, 2009 at 11:08:25pm
On 3rd Feb, 2009 just_jack said:
what horsepower does the DON run??? (i dont think this should be in this catergory but it saves opening another topic) Tom posted an extract from a dyno sheet showing 220 once but I've a hunch that it's capable of more given the turbo choice. Edited by Rob H on 3rd Feb, 2009. Isambard Kingdom Brunel said:
3rd Feb, 2009 at 11:44:03pm
standard turbo with intercooler you dont wand to be going over 120 bhp
![]() 233 Posts Member #: 863 Senior Member Lathom, lancs |
12th Feb, 2009 at 03:43:52pm
ive been told to run about half a bar as a safe amount on a good condition std metro engine, i wil be running 7 psi to get everything sorted and iron out any niggles in the setup then i will build my other engine up to a much better spec.
13th Feb, 2009 at 08:03:37pm
thanks guys Jack Jones |
13th Feb, 2009 at 08:38:20pm
PS- there is no such thing as "waste gate chatter" please alter your signature!!!!!!!
13th Feb, 2009 at 09:19:16pm
On 13th Feb, 2009 Tom Fenton said: PS- there is no such thing as "waste gate chatter" please alter your signature!!!!!!!
Yes i moved to the darkside |
18th Feb, 2009 at 12:25:27am
hey tom, this is why my questions are under immature and beginner, because i dont really have a clue, but alas i will try
Edited by just_jack on 18th Feb, 2009. Jack Jones |
18th Feb, 2009 at 08:20:06am
On 18th Feb, 2009 just_jack said: compressor surge
what is the noise i am thinking of called??? Yes i moved to the darkside |
18th Feb, 2009 at 02:07:50pm
change waste gate for Turbo and it will make more sense. |
18th Feb, 2009 at 05:35:30pm
PS- there is no such thing as "waste gate chatter" please alter your signature!!!!!!! technically, (just to piss you off tom !) i had wastegate 'chatter' i bought a recon turo off ebay, and the actuator was set miles too loose, leaving the wastegate a midges dick open, and under no tension. when i first started it up, i though the turbo was fucked, but fortunately a tweak here and there and violla. but the sig is still hugely misguided, youve got to love a good dump! "Turbo's make torque, and torque makes fun"
18th Feb, 2009 at 07:20:16pm
i had a word with a lad at work and it said the noise i am thinking of (which i first heard on his 620ti) is the throttle butterfly 'chattering' as the throttle is closed, after the turbo is nearing max boost
Jack Jones |
18th Feb, 2009 at 08:05:59pm
right. when you close the throttle from being on boost the air then hits the butterfly. correct.
22nd Feb, 2009 at 04:38:12pm
thank you james, very well explained Jack Jones |
