| Home > General Chat > Supercharger Questions | |||||||
559 Posts Member #: 2775 Post Whore Aberdeen |
4th Feb, 2009 at 09:34:53am
Has anyone done or seen a weber supercharger kit that fits under
301 Posts Member #: 2480 Senior Member Swindon |
4th Feb, 2009 at 12:31:59pm
If you can make a weber manifold and fit it on the end of the drainpipe set up that the SU one uses, i guess it could work. I just bolted mine to the charger and as you stated, needed to cut the bonnet to fit. Im sure ive seen a weber used on the SU setup before feature=mhum |
4th Feb, 2009 at 04:35:04pm
That along the lines of ehat I am planning was to stick it down the front with an Itg open ended filter (ie no metal plate) I just wander what the downfalls are because nobody seems to do it that way |
