| Home > Help Needed / General Tech Chat > wiring up | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
4th Feb, 2009 at 11:35:40am
Hi guys.
4th Feb, 2009 at 12:13:43pm
On 4th Feb, 2009 Alex1340 said:
At the same time I need to wire up two electric fans, is it naughty to wire both on one relay? Or should I have one per fan. What matters is whether the relay/fuse/wiring rating is adequate for the combined current. Read the currents off the two fans, add them and then decide (most relays are either 30A or even 40A) On 4th Feb, 2009 Alex1340 said:
Also the electric fuel pump should be on a relay as well?? Any engine with EMS would require it (as the EMS decides when the pump should run, not the ignition switch). If it's a high pressure pump I would use a relay even on a carb'd engine. However, IMHO, the more important thing - if the pump can generate any real pressure - is to wire it through an intertia switch. Even without EMS there are ways of wiring it (through a relay) that shut it down if the engine stops (ie, using a feed from the oil pressure switch, or the earlier Ford/VW timer relays), but when you really want it to stop is in the event of a shunt..... Just my opinion.... Schrödinger's cat - so which one am I ??? |
4th Feb, 2009 at 12:16:00pm
IT's one of those questions, that if you have to ask then you already know the answer...
4th Feb, 2009 at 09:39:08pm
yeah your right. least if evey thing is seperate then if 1 replay goes then the other will be running. Also found this web site which is SOOOOOOOOOOOO much cheaper than others i have found
