| Home > Help Needed / General Tech Chat > Braided Oil Feed Conections | |||||||
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
7th Feb, 2009 at 12:07:37pm
Hi all, just got my braided oil line from minispares after my origional split again, and I assumed it'd be banjo unions on either end but it's not. Just wanted to check this is the right way of connecting them up.
7th Feb, 2009 at 12:26:54pm
I cant see the pic, but i assume you mean the turbo feed? The banjo ends goes on the turbo and the other end you can use with a t piece into the block. |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
10th Feb, 2009 at 12:39:58am
Yes the T comes of the block end and you use one end of the T for your oil pressure switch.
10th Feb, 2009 at 12:42:34am
what happpend to the one i braized up for you tom ?
10th Feb, 2009 at 01:39:23pm
It split again just up from the brazed section Steve, on the bend. I think the previous owner had bent it in all shapes as theres stress marks on all the bends! I wouldn't put it past him to be fair with the state the engine was in.... |
10th Feb, 2009 at 05:47:32pm
not to worry tom as long as you get things sorted buddy
10th Feb, 2009 at 10:00:19pm
All fitted now and running. No leaks etc so it's looking good! *Touch wood for a trouble free week!!* |
