Home > Help Needed / General Tech Chat > mini only runs with chocke out
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello all
need your helo again have a friend who has just brought a mini and it will only run with the choke out if you push it in it coffs and splutters can you help please
it also leeks fuel from the carb he thinks its from the overflow
again any ideas thanks again
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
If it doesnt like no choke then I guess the mixture is too lean, tell him to richen it up a bit so it'll idle with no choke when its up to temp.
Edit, actually im not sure because of the fuel leaking aswell someone else can help.
Edited by richminiturbo. on 7th Feb, 2009.
there is a load of things to check over first, i would fix the carb sounds like ()presuming no holes in it) the needle that cuts the fuel from going into the carb is stuck open, this could be because of dirt in the float bowel, punctured float, dodgy needle, and maybe more i cant think off
once thats sorted check the dashpot for oil top up with engine oil, doesnt need to be over flowingpressing the float bowel dipstick down you shold feel resistance all the way from top to bottom,
next, what air filter/ exhaust does it have my guess is its had a 'stage' 1 kit fitted but no new needle (my mayfair was like this and gave those symptoms)
iirc the standard needle is AAU.. and for standard 'stage' 1 you need AAA again dont quote me but im sure thats what i needed the other option it to take it for a rolling road tune, more expensive but the engine will be tuned and setup accurately *happy*
alandavies215
Member #: 1844
Hello
Just an update just been round to have a look at said mini, looking around the carb and it was a bit damp but nothink major then took a look underneath
There is petrol dripping on the verge of running from the split pin at the bottom of the clutch casing (the drain hole I think) then checked the dip stick and it is Reading nearly to the top of the dip stick
I know this looks bad but how bad
Thanks for your help again
sorry dont think i under stand? Fuel has leaked out the carb into the sump (and filled it)and is now leaking out the clutch housing?
EDIT hang on a minute have u checked the fuel pump? Maybe that pissing into the engine
If fuel is in the oil it needs changing but fix the fuel leak first dont run the engine untill the oil is changed
Edited by Brett on 7th Feb, 2009.
alandavies215
Member #: 1844
No sorry he originaly told me it was coming from the carb
But when I got there it was dripping (running) out of that hole at the bottom of the clutch housing,
my guess is the fuel pump diafragm (sp?) Has split not un common
alandavies215
Member #: 1844
Hello again
Should it be leaking even when it is not running (not even been started)
From the latest description, I agree 100%
Yes, it will still flow slowly through the split diaphragm with the engine off if (a) the tank level is high enough or (b) a syphon has started from last time it was run.
As stated, do NOT run the engine with that much fuel in the oil.
Best outcome, shot bearings, worst, a large bang......
The actual fix is simple (new pump and change the oil/filter) but not if it gets run like it is now.....
alandavies215
Member #: 1844
Thanks guys I appreciate it
