| Home > Wanted > Standard pressed steel rockers | |||||||
7th Feb, 2009 at 06:57:29pm
Just looking a set of the earlier pressed steel rockers. Apparently there is a difference between large bore and small bore ones, I am looking the large bore ones with the larger pad area as seen in the bottom of the pic:
On 7th Nov, 2008 Nic said:
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
7th Feb, 2009 at 07:25:49pm
I'm pretty sure i have some, i'll check. :) |
10th Feb, 2009 at 06:01:43pm
10th Feb, 2009 at 07:32:41pm
Sorry totally forgot, will go & check tonight ! :) |
3rd Mar, 2009 at 11:07:01pm
Well Phillip if you don't want to sell the rockers you only have to say Edited by Jay#2 on 3rd Mar, 2009. On 7th Nov, 2008 Nic said:
3rd Mar, 2009 at 11:14:49pm
Oh bollocks !!!!!! Right i promise i will look tomorrow. Sorry mate. |
4th Mar, 2009 at 09:48:17am
I've got 7 of the pressed steel type.
In the 13's at last!.. Just |
5th Mar, 2009 at 10:34:20pm
Are you still after these J ? I have two sets, just need to double check they're the wider ones. |
6th Mar, 2009 at 07:56:33am
Yes Phil, still looking a set. Thanks for checking this up for me, if you let me know what you find that would be great :). Thanks also oneeyedlizard man, we'll see what phil turns up. On 7th Nov, 2008 Nic said:
6th Mar, 2009 at 08:13:48am
I might be interested in one of these. What ratio are they? They're not 1:1 like ordinary rockers (or am I talking out of my arse again??)
On 5th Mar, 2009 Turbo Phil said:
Are you still after these J ? I have two sets, just need to double check they're the wider ones. On 11th Feb, 2015 robert said:
6th Mar, 2009 at 08:44:49am
They are the highest ratio of the standard rockers (1.27:1) and can be modded ala Vizzard making them quite strong. Considering you cant get decent 1.3:1 rollers any more then a good option I guess! On 7th Nov, 2008 Nic said:
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
6th Mar, 2009 at 06:54:40pm
ypu can get deent 1.3:1 roller rockers...avonbar sell em On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
6th Mar, 2009 at 08:18:15pm
Got a set ! :) |
6th Mar, 2009 at 09:37:45pm
Avonbar sell the Titan full rollers in 1.3 yes, but I don't want full rollers really. OK Phil PM sent! On 7th Nov, 2008 Nic said:
! Just trying to avoid 1.5s or dodgy Minisport 1.3s
. Anyone?
