| Home > Help Needed / General Tech Chat > Two radiators? | |||||||
![]() 367 Posts Member #: 1643 Senior Member West London |
8th Feb, 2009 at 05:22:12pm
Does anyone run two rads? One either side maybe, or one on the normal passenger side and one up front.
Lightweight racer coming soon. |
8th Feb, 2009 at 05:32:21pm
it is under his boot floor i beleive.
8th Feb, 2009 at 05:32:26pm
EDIT. double post. only clicked once and no refresh......wierd.... Edited by James_H on 8th Feb, 2009. |
9th Feb, 2009 at 09:01:47am
yes its under the rea subframe
9th Feb, 2009 at 02:52:45pm
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
9th Feb, 2009 at 02:56:48pm
I run a full on ali job and a decent electric fan, havn't had problems with overheating at all. I beleive the wetr water product works quite well (so i have been told)
"Cars are a lifetime of pain" |
9th Feb, 2009 at 07:59:37pm
Just a note - oil coolers are the most inefficient way of cooling water on a car - you are better off with a heater matrix!
On 5th Sep, 2011 Vegard said:
16 Posts Member #: 567 Member |
9th Feb, 2009 at 09:37:26pm
hi i run two full size rads in my blue car one either side the normal rad is std the second rad is again a std rad but with a bottom rad cap placed on the top. the rad cap has the pressure releif part cut out and run a metro expastion tank run is as follows
9th Feb, 2009 at 10:47:09pm
Thanks chaps, was just a question tbh, not sure if I plan on doing it yet!
10th Feb, 2009 at 07:31:29pm
Thanks a few more at www.moose-motorsport.co.uk but here is a taster with an engine bay shot where you can almost see it has two rads!
10th Feb, 2009 at 07:40:54pm
Scruffy, I hadn't seen pics of your car before. It's a bleedin minter 8-) On 12th Nov, 2009 Paul S said:
Gary's description is best |
10th Feb, 2009 at 07:41:08pm
On 9th Feb, 2009 Scruffy said:
Just a note - oil coolers are the most inefficient way of cooling water on a car - you are better off with a heater matrix! . But better than nowt.... I work on CT scanners that are water cooled, the radiators we use are not much different than an oil cooler, and just about the same a s the oil cooler we use... OK a heater matrix may be more efficient but its also half the size. Edited by Turbo Tel on 10th Feb, 2009. website:- http://www.terryhunt.co.uk
10th Feb, 2009 at 07:41:26pm
Love that!! Once I'm done I'll prob see you at combe Lightweight racer coming soon. |
10th Feb, 2009 at 07:44:12pm
scruffy, is that sat on 10's? looks nice Yes i moved to the darkside |
10th Feb, 2009 at 07:46:14pm
10" spectrums by the looks of it or maybe a set of carls rims?
11th Feb, 2009 at 07:42:28pm
Original spectrums 7x10 with 180/490 slicks
