Home > Help Needed / General Tech Chat > Suspension Question
Tom H
Member #: 1670
I am currently repairing and rebuilding my subframes and i wanted to uprate my usspension componants, I want a fast road set up which i can use on the odd hill climb. I believe the kit below is the one i should go for just asking some for some advice on the matter - will be using spax adjustable dampers and high lows too
http://www.minispares.com/Product.aspx?ty=...=0&tc=1#submenu
tom
That is the kit I would buy, fully adjustable, well made, well priced and robust.
I have the same stuff on my hillclimber, but mine is all rosejointed.
Tom H
Member #: 1670
Thanks alot wil_h
i have the same kit too with red dot cones and gaz adjustables, very very well made,
Radleigh
Member #: 1643
West London
That saves me a post, I was looking at that kit the other day too!! Cheers guys.
quinton
Member #: 1911
I'm gunna run gaz with standard cones and see how they do. wanna see what body roll i get. otherwise its red dots but are they any good for their price?
Tom H
Member #: 1670
i too and going for the standard cones as mine are only a few yrs old, but i might replace if they look past their best when i remove them properly as the fronts are still in a the rear frame is being replaced due too rot
the minispares cones (red and yellow) are not only stiffer but the spring rate is tuned for the length of the stroke, i dont know any details of the changes but comparing the standard item and the red dots i have the rubber is a very different shape, alot of guys rate this setup over coilovers, Wil_h uses these on his hillclimber mini, its his setup i have almost copied
EDIT sorry Wil its a hillclimber*happy*
my cones was cracked and the metal base ring had parted company so i had to buy new anyway and extra 20quid per corner aint alot
Edited by Brett on 9th Feb, 2009.
Saved me a post too.
I'll be buying that kit and all ready have brand new standard cones and spax gas shockers.
Scruffy
Member #: 328
Seaford Rise, South Australia
Make sure you ask to pay extra to have the adjustable rear toe type brackets those in the kit are camber only
On 5th Sep, 2011 Vegard said:
t3gav
Member #: 229
Gavin@minispares.com
kent
That kit comes with shims, you can use MSSK3013 if you prefer adjustment on the rear brackets.
Tom H
Member #: 1670
thats all and gavin, i shall be up to minispares north on saturday to pic up the kit
Scruffy
Member #: 328
We prefer adjustment!
